562
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. Tee_Eee_Bee
    Ice Cream Sandwich Sep 30, 2020
    Tee_Eee_Bee , via OnePlus 8 Pro , Sep 30, 2020 :
    You are using the roll back package for your device/region as linked in the first post?
    Want to go back to MP? Download the Rollback package from the links below:
    If they don't appear to be working, tap on the 3 dots in the top right hand corner and tap "Open with browser" and it should download.
    Also, remove the '.jar' file extension if present by renaming the file using file manager.
    * edited to show links
  2. nikem154
    Cupcake Sep 30, 2020
    nikem154 , Sep 30, 2020 :
    I already did download it but it gave me error . I am uploading screen shot.
  3. nikem154
    Good luck wasting your time typing. People should mind their own business if not going to share some usefull information .
  4. evnsriram likes this.
  5. Tee_Eee_Bee
    Tee_Eee_Bee , Sep 30, 2020 :
    It looks to me like you are trying to roll back using the current software version available on the OnePlus support page.
    You need to download the rollback package for your device/region from the first post of this thread or it won't work.
  6. Toni Merikanto
    Gingerbread Sep 30, 2020
  7. CD0
    Eclair Sep 30, 2020
    CD0 , via OnePlus 8 Pro , Sep 30, 2020 :
    Did you use the rollback zip in the OP? Or did you download from the support page?
    The zip is located lower down from where you downloaded the beta file. You can only use these otherwise you'll keep getting that error.
  8. N8Smith
    N8Smith , Sep 30, 2020 :
    Is it not possible to try out the beta if you are a T-Mobile customer? I bought my Oneplus 8 from T-Mobile and have been trying to update my phone to no avail. 🤔😑😔
  9. N8Smith
    Did you get the update?
  10. Tee_Eee_Bee
    In the past T-Mobile have had their own release schedule for their branded devices (at least they did for the 6T) so you may have to wait for them to release a stable update.
    N8Smith likes this.
  11. N8Smith
    N8Smith , via OnePlus 8 T-Mobile , Sep 30, 2020 :
    Thanks for the response my friend.
  12. Harishsivakumar96
    Honeycomb Oct 1, 2020
    Harishsivakumar96 , via OnePlus 3 , Oct 1, 2020 :
    MX player not working is mainly because it currently does not support oxygen os 11. I mean not optimised for. Wait for sometime till mx player pushes an update in playstore . In the mean time you can try clearing cache from storage and see if it help
    G1592674411026 likes this.
  13. G1592674411026
    Cupcake Oct 1, 2020
    G1592674411026 , via OnePlus 8 Pro , Oct 1, 2020 :
    And what about heat problem ?
  14. jayphoenix2010
    Cupcake Oct 1, 2020
    jayphoenix2010 , Oct 1, 2020 :
    Anyone experiences noticeable black crush on OnePlus 8 even after this upgrade? I am experiencing the same.
    Turning DC Dimming ON/OFF isn't helping much. Any official statement for fix? or It's hardware issue?
  15. Harishsivakumar96
    Honeycomb Oct 2, 2020
    Harishsivakumar96 , via OnePlus 3 , Oct 2, 2020 :
    Heat problem what heat problem . It's a beta for heaven's sake u will definitely face a lot of bugs crashes random reboot. Its sole purpose is to filter out the bugs. If u face issues submit the logs in the feedback section.so that if it's a problem with oxygen os they will rectify it.
  16. Ankur_Faujdar
    Cupcake Oct 2, 2020
  17. k4ustu3h
    Froyo Oct 2, 2020
