568
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. JoeBuj
    Cupcake Sep 9, 2020
    JoeBuj , Sep 9, 2020 :
    Is "main storage" is specific folder I need to find. Or just anywhere internally?. I removed the .jar and it's still not showing up.
  2. atulsngh37
    Cupcake Sep 9, 2020
    atulsngh37 , Sep 9, 2020 :
    Does Amazon upi works for you ?
    Please reply!
  3. amitpharande
    Eclair Sep 9, 2020
    amitpharande , Sep 9, 2020 :
    Those who are saying Rom not visible in Local Upgrade Section....Please rename your extension .jar rom file to .zip...it will be visible.
  4. joselilloaleman , via OnePlus 8 Pro , Sep 9, 2020 :
    Have the same issue when scrolling on dark mode + gray boxes
  5. Reviaro
    Cupcake Sep 9, 2020
  6. AbdNz
    Gingerbread Sep 9, 2020
  7. cccchug
    Eclair Sep 9, 2020
  8. Harshu01
    Donut Sep 9, 2020
  9. AbdNz
    AbdNz , via OnePlus Nord , Sep 9, 2020 :
    It will get for sure but wait for some time, first they will provide the upgrade to the flagship series
    A1597069246176 likes this.
  10. amitpharande
    Eclair Sep 9, 2020
    BTW be careful if you are upgrading to Open Beta...in case you wanna roll back to Android 10 your device will be fully wiped including Internal Storage while rolling back....Happened with me while i'm on DP4 and rolling back to Stable Android 10.
    P1588877484374 likes this.
  11. palc
    Ice Cream Sandwich Sep 9, 2020
    palc , via OnePlus Nord , Sep 9, 2020 :
    Why did you not read the DP4 thread?
    If you're on DP4 it will and it should erase your data. DP4 to any version will erase data. Even if it doesn't, you should erase your data and do a clean install coz there's a difference between developer "preview" and open betas. Even the name as the word preview. You will face issues if you don't do a clean install.
    If you're on a stable build, going to open beta will NOT erase your data. If you're on an open beta, upgrading to another open beta will NOT erase your data. However, while downgrading you should and it's recommended to erase your data if it already doesn't.
    If you're on an open beta build, going to stable WILL erase your data (and if by chance it doesn't, you should do it, a clean install, so as to avoid issues).
    Hope that clears all the confusion about "erase data or not" and those posts stop coming.
  12. Mashrur Dewan
    Cupcake Sep 9, 2020
  13. cccchug
    Eclair Sep 9, 2020
  14. Jindal Shivam
    Eclair Sep 9, 2020
    Jindal Shivam , via OnePlus 8 , Sep 9, 2020 :
    I renamed the folder and removed .jar from it, but now I see automatically .zip is also removed from the folder name and it says MAXIMUM CHARATERS REACHED. anyone facing this issue?
  15. Kriti Karna
  16. Udaya_Chendur
    Honeycomb Sep 9, 2020
    Udaya_Chendur , via OnePlus 5 , Sep 9, 2020 :
    I understand. Is there any word on it? This seems too small for such a large screen. 3 rows would be fine.
  17. Andy lone
  18. magento
    Eclair Sep 9, 2020
  19. Harshil__07
    Harshil__07 , Sep 9, 2020 :
    The Black Crush and the green tint is gone??
