564
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. shahaagam95
    Donut Sep 9, 2020
    shahaagam95 , via OnePlus 8 Pro , Sep 9, 2020 :
    After updating to the Oxygen OS11, I noticed that the 5G option isn't available anymore.
    Has anyone else faced the same kind of issue, if so, were you able to find a solution for it?
  2. SteveCP
    Jelly Bean Sep 9, 2020
    SteveCP , via OnePlus 8 Pro , Sep 9, 2020 :
    Are you from India? This firmware isn't fully compatible for Indian users as per the first.post. has added the action in the UK and US
  3. U1580007062575 , via OnePlus 8 Interstellar Glow , Sep 9, 2020 :
    They are so broken that I'm on whatsapp inside the app and I'm still being showed that massive chunk of notifications and I can't read nor use the app properly
  4. Q1595931399062
    Cupcake Sep 9, 2020
  5. StrikerZ
    Eclair Sep 9, 2020
  6. Azzlan786
    Eclair Sep 9, 2020
    Azzlan786 , via OnePlus 8 , Sep 9, 2020 :
    Netflix and Google Pay are working fine for me on this build. Using OnePlus 8 IN2013.
    Battery is draining quite quickly though. Might take a couple of days for the OS to settle in.
    Will keep you all updated.
    EtienneQuesselaire likes this.
  7. Camberley_Chris
    Cupcake Sep 9, 2020
    Camberley_Chris , Sep 9, 2020 :
    Sorted now, didn't select correct setting in Updater. Now exploring Android 11.😁😁😁
    gregstinson likes this.
  8. Godfather 1
    Godfather 1 , Sep 9, 2020 :
    Du
    Are you in uae?
  9. gregstinson
    Donut Sep 9, 2020
    rootcoors likes this.
  10. iampun33t
    Gingerbread Sep 9, 2020
    iampun33t , Sep 9, 2020 :
    To all those who are facing the very Large Font/ Display Size: One solution has been found.
    Check the "Smallest Width" setting in the Developer Options. It should be around 384 dpi.
    It seems to resolve the scaling issue, mostly.
  11. gregstinson
    Donut Sep 9, 2020
  12. shazamdoes
    Cupcake Sep 9, 2020
  13. Supergamer65
    Cupcake Sep 9, 2020
  14. iampun33t
  15. T1598053852410
    Cupcake Sep 9, 2020
  16. rootcoors
    Cupcake Sep 9, 2020
  17. zfhz2012
    Cupcake Sep 9, 2020
  18. Godfather 1
    It'll take some time..
    You can download the latest Oneplus apps..if you want a taste..they have been updated to android 11.
    From apkmirror btw...(totally your call)..
  19. samw5
    Cupcake Sep 9, 2020
    samw5 , Sep 9, 2020 :
    Upgrade from MP went smoothly on my 8Pro.
    Dual SIM works!!!! Google Pay no longer does :(
    UI looks ugly... fonts somehow seem huge. Not too happy about that. Hopefully things will get better as it progresses.
    Camberley_Chris likes this.
