554
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. rakimahi17
    Cupcake Sep 9, 2020
  2. damiansixx
    Eclair Sep 9, 2020
  3. IgorBizic
    Eclair Sep 9, 2020
  4. DjStallion101
    Cupcake Sep 9, 2020
    DjStallion101 , via OnePlus 8 Pro , Sep 9, 2020 :
    Didn't see you needed to rename file thanks community
  5. Liehjan
    Marshmallow Sep 9, 2020
    Liehjan , Sep 9, 2020 :
    Remove the .jar from the file name.
    DjStallion101 likes this.
  6. Liehjan
    This is the global rom, don't expect Indian specific features in the global rom.
  7. Kishore__11
    Cupcake Sep 9, 2020
  8. Q1549381928352
    Cupcake Sep 9, 2020
  9. Jericho_Kem
    Cupcake Sep 9, 2020
    Jericho_Kem , via OnePlus 8 , Sep 9, 2020 :
    Hi Guys. Just downloaded and installed. Looking great! Just had one issue when I installed it, I found the letter and display size a bit to big, so I wanted to turn it down a bit. Once done this the letter or display size (i do not know which one exactly) became bigger instead of smaller, but the system says it is on small. And i cannot undue this anymore. Anyone else bumped into this, or has a way to undo this (besides uninstalling the beta)
  10. Supergamer65
    Cupcake Sep 9, 2020
  11. Scherpenseel
    KitKat Sep 9, 2020
    Scherpenseel , Sep 9, 2020 :
    Then you can keep waiting forever... There are no beta's anymore for OP6/OP6T.
    There is literally an explanation couple posts above you... When are you going to learn that you read first, ask questions after.
    ade0410 and SteveCP like this.
  12. Supergamer65
    Cupcake Sep 9, 2020
    Supergamer65 , via OnePlus 8 Pro , Sep 9, 2020 :
    Google Pay is working again after the reboot.
  13. Scherpenseel
    KitKat Sep 9, 2020
    And as a true beta tester, what did you do to report/solve it?
  14. IgorT76
    Gingerbread Sep 9, 2020
  15. premsonu118
    Froyo Sep 9, 2020
    Deactivated User likes this.
