564
[SURVEY INSIDE] OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. gregstinson
    Donut Sep 9, 2020
    gregstinson , via OnePlus 8 Pro , Sep 9, 2020 :
    Use the Oxygen Updater app from Play Store...
  2. beuz12
    Froyo Sep 9, 2020
  3. SteveCP
    Jelly Bean Sep 9, 2020
    SteveCP , via OnePlus 8 Pro , Sep 9, 2020 :
    Yes it is, you need to set it on using ambient display in settings
  4. sajdog
    Donut Sep 9, 2020
    sajdog , via OnePlus 8 Pro , Sep 9, 2020 :
    Hello. Downloaded but when I try to do system upgrade says move package to root directory. The package is already on internal storage. What else do I need to do
  5. SteveCP
    Use the link to download on the first post you will not receive this as OTA
  6. SteveCP
    Rename the file to .zip not .zip.jar
  7. beuz12
    Froyo Sep 9, 2020
    beuz12 , Sep 9, 2020 :
    [QUOTE = "SteveCP, post: 22079400, membre: 2365485"] Oui, vous devez l'activer en utilisant l'affichage ambiant dans les paramètres [/ QUOTE]
    Je l'ai configuré mais je n'ai pas le nouveau Always on display sur l'affichage je n'ai que mon horloge qui s'affiche et pas la nouvelle barre
  8. sajdog
    Donut Sep 9, 2020
  9. muffin.man
    Donut Sep 9, 2020
    muffin.man , via OnePlus 8 Pro , Sep 9, 2020 :
    Is there a problem with the colours shifting whenever the keyboard pops up on the screen while in dark mode? For me whether in WhatsApp or Facebook, when the keyboard pops up, there's a slight change in colours (kinda yellowish) This is at low darkness. Didn't have this issue before the update
  10. Sudharsan710
    Cupcake Sep 9, 2020
    Sudharsan710 , via OnePlus 8 Pro , Sep 9, 2020 :
    After updating open beta I can't edit my slow motion video... If I press edit button it shows only trimming option.. And There is no option for editing the slow motion area.. Plz fix this bug..
  11. _Bugs_Bunny_
    Cupcake Sep 9, 2020
  12. DeadEyeP
    Froyo Sep 9, 2020
  13. SteveCP
  14. SteveCP
    Send your report via the bug forum on post 1
  15. L1595859979707
    Donut Sep 9, 2020
    L1595859979707 , Sep 9, 2020 :
    It's ridiculously large, when i swipe down I only see for options whereas there used to be 8, how do I change that?
  16. sajdog
    Donut Sep 9, 2020
  17. SteveCP
    It needs to be all day or schedule here
  18. SteveCP
  19. tvanverseveld
    Cupcake Sep 9, 2020
    tvanverseveld , via OnePlus 8 Pro , Sep 9, 2020 :
    After having used the Open Beta for about one day on my OnePlus 8 Pro, I noticed some things that were missing / didn't work as intended:
    - The "Contextual Info" settings page (Settings -> Display -> Ambient Display) keeps crashing.
    - Whenever I'm in Landscape mode, when I return the my home it's looking really buggy.. The home starts in Landscape mode and switches over after around 2 seconds
    - I'm really missing the halo around the selfie camera whenever it is active
    - The overall experience is pretty good, but during gaming it sometimes feels very laggie as if my whole phone just stops working for a sec
    - Is there a way to change the color of the icons itself inside the notification shelf for the different buttons (WiFi, Bluetooth, etc.)
    - Is there a way to track how much power the Always On Display uses?
    - I used Spotify for about 4 hours while my screen was off, but the battery detailed usage says it has taken 29% of my battery (even more then my screen which is on 120hz and 1440p) and it says it only runned for about 5 minutes as background application (which is weird because my screen was off for practicaly the entire 4 hours). Not sure of this is a bug with the new way of displaying current music/videos, or just something Spotify needs to fix?
    As mentioned before, the overall experience is really good! The new font needed a bit of getting used to, but it really growed on me!
    Hopefully you guys can address the above issues within the next update! :D
    Also, how do updates work? Just like normal updates or do I have to download the updates manually like I did with the open beta? Thanks!
    J1597106787290 likes this.
