52
[SURVEY INSIDE] OxygenOS 11 Open Beta 10 for the OnePlus 8 and OnePlus 8 Pro
  1. Aaron2017
    KitKat May 27, 2021
    Aaron2017 , May 27, 2021 :
    Did you copy it to your internal storage? Also, if it ends with .jar remove that. It should have .zip at the end
  2. S1600545260844
    Cupcake May 27, 2021
  3. Sado0og
    Gingerbread May 27, 2021
    Sado0og , May 27, 2021 :
    I always go back and forth between stable and beta
    But this time i do not know what the problem...
    I downloaded using ox updater apk... it's there in internal... check the name and it end with zip no jar..
  4. Aaron2017
    KitKat May 27, 2021
    This happened to me once before too with oxygen updater. I used the link from XDA instead and could install that no problem. Maybe try that as well? Weird, because the app always worked fine other than that one time
  5. L1604741068424
    Eclair May 27, 2021
    L1604741068424 , via OnePlus 8 Pro , May 27, 2021 :
    What kind of survey are you asking from customers .. we dint received any open beta 10 for one plus 8pro .. when you are not providing any major update to customers then why are you asking about feedback .. poor feedback from one plus .. you dont deserve to get good feedback as you are cheating customers.. you don't give appropriate update to customers .. You are not doing false promises to one plus customers..you are not a premium company anymore ..
    777prototype777 likes this.
  6. Sado0og
    I have fixed it
    The system was the issue
    I just reboot my phone everything works fine
    Aaron2017 likes this.
  7. Aaron2017
    KitKat May 27, 2021
    It's a survey for those that are on the beta channel, one that you're not on given you haven't received this update.
    Arjun_Choudhry likes this.
  8. 1+PremWani
    S160976256283 likes this.
  9. @CHINITA
    Cupcake May 28, 2021
  10. iamincrediblemihai
    Eclair May 28, 2021
  11. 1+PremWani
    Gingerbread May 28, 2021
  12. DeepThapa
    Froyo May 29, 2021
    DeepThapa , via OnePlus 8 Pro , May 29, 2021 :
    Please send an OTA update for Display issues such as green tint, black crust and punch hole camera bar ! It's been a whole year but no improvement ?
  13. Parthkansara
    Gingerbread May 29, 2021
  14. Y1611756184884
    Donut May 30, 2021
  15. venkys1437
    Cupcake May 30, 2021
    venkys1437 , via OnePlus 8 Pro , May 30, 2021 :
    Kindly some one suggest me ..I have recently updated the latest security may patch for OnePlus 8pro..I contact page is displaying.but I can't make call ..
  16. Tee_Eee_Bee
    Ice Cream Sandwich May 30, 2021
  17. L1604741068424
    Eclair May 30, 2021
    L1604741068424 , via OnePlus 8 Pro , May 30, 2021 :
    When we are getting open beta 10 for one plus 8 pro .. please provide update as soon as possible .. why you are taking so much time to give updates ..don't give minor changes to us in updates ..
  18. Aaron2017
    KitKat May 30, 2021
    Aaron2017 , May 30, 2021 :
    If you want to switch to the beta channel you have to download and install it yourself, otherwise OnePlus can't give you beta updates.
