52
[SURVEY INSIDE] OxygenOS 11 Open Beta 10 for the OnePlus 8 and OnePlus 8 Pro
  1. L1604741068424
    Eclair May 30, 2021
    L1604741068424 , via OnePlus 8 Pro , May 30, 2021 :
    Atleast give the stable versions at time or that also we have to download by ourselves.. what you show at your one plus page about updates you should give that updates only.. why are you doing false promises to your customers this is the kind of trust you are giving to your customers... Neither you provide anything in your accessories all stuff of one plus 8pro is out of stock ..
  2. Aaron2017
    KitKat May 30, 2021
    Aaron2017 , May 30, 2021 :
    I can't give you anything and i certainly didn't promise you anything, we are all just users here. If you haven't received the latest update yet and don't want to wait for the staged rollout to reach your device, than yes, you can download and install it yourself if you want it quicker.(if it's released for your region). Other than that nobody here can help you when it comes to update releases (or lack thereof)
    Arjun_Choudhry likes this.
  3. L1604741068424
    Eclair May 30, 2021
    Who are you ? Are you working in one plus ? if you are a normal user so you don't know anything .. so don't give useless replies and baseless replies .. one plus can't promsie anything .. they don't give appropriate updates .. if you don't know anything don't be a leader .. if you can do anything for customers then you should reply to customers .. we are not fools here .. buying your expensive devices .. are you gifting us your phone's .. so better to improve quality don't mess with customers..
  4. Aaron2017
    KitKat May 30, 2021
    I'm just a user, who knows as much about updates as the rest of us here. I do know how to get beta updates, which you asked about and i answered, and i also know the quickest way to get stable updates when they are released (and if available for your region), which i also told you about. If you think those are useless replies than nobody can help you here, only other users will reply to you and you won't get a response from OnePlus on this forum. Would it be nice to get monthly updates? Yes. Would it be nice to get the bi-monthly updates in the beginning of the month rather than at the end? Also yes. But that isn't the reality and unfortunately you, me or anybody can do anything about that.
  5. bpwest80
    KitKat May 30, 2021
    bpwest80 , via OnePlus 8 Pro , May 30, 2021 :
    I've lost around an hour of SOT on beta 10. Beta 8 and 9 had better battery life for me. I used to get close to 6hrs SOT but on beta 10 I haven't even gotten over 5hrs SOT. I haven't changed anything on my phone other than going from beta 9 to beta 10.
  6. vineetn12
    Eclair May 30, 2021
    vineetn12 , via OnePlus 8 , May 30, 2021 :
    Next update will come
  7. 1+PremWani
    Gingerbread May 31, 2021
    1+PremWani , via OnePlus 8 , May 31, 2021 :
    Updates are pushed in slots, don't worry it'll definitely come to you.
    S160976256283 likes this.
  8. S1600545260844
    Cupcake Jun 1, 2021
  9. bpwest80
    KitKat Jun 1, 2021
  10. prfraczek
    Honeycomb Jun 1, 2021
    prfraczek , Jun 1, 2021 :
    me 2. Yesterday I was driving with Waze and charger plugged in and 8Pro showed me high temperature and dimmed all screen down after 15 minutes of driving. In UK 22 deg outside and aircon turned on. The new model should be named '1+mistake' :p
    kp17, 777prototype777 and bpwest80 like this.
  11. bpwest80
    KitKat Jun 1, 2021
    bpwest80 , via OnePlus 8 Pro , Jun 1, 2021 :
    My 8 Pro has been randomly dimming the screen for no reason. So annoying. I can barely see it until I manually adjust. Auto brightness isn't working very good on beta 10. I just can't wait for the 6 Pro. Won't have to worry about updates then and have much better cameras! Me and my wife will be getting one!
    CD0, 777prototype777 and prfraczek like this.
  12. bpwest80
    KitKat Jun 3, 2021
    bpwest80 , via OnePlus 8 Pro , Jun 3, 2021 :
    Forgot I had digital gene turned on. Maybe that's why my battery on OB10 has been worse because I didn't have it turned on before. I just forgot about it.
  13. 1+PremWani
    Gingerbread Jun 3, 2021
    1+PremWani , via OnePlus 8 , Jun 3, 2021 :
    Switch to stable
  14. bpwest80
    KitKat Jun 3, 2021
  15. arvindjandu305@g
    Cupcake Jun 3, 2021
  16. Aaron2017
    KitKat Jun 3, 2021
    Aaron2017 , Jun 3, 2021 :
    I guess he means for better battery life. Although i doubt at this point there's much difference between the two.
  17. AlejoLinardi
    Cupcake Jun 3, 2021
    AlejoLinardi , Jun 3, 2021 :
    On this matter, would be great if someone that tried both the latest stable and beta would give its opinion on battery life of both versions. Which one is better?.
  18. Aaron2017
    KitKat Jun 3, 2021
    Indeed, that's the only way to be able to tell which one is better in terms of battery. I've seen both good and not so good battery life reports on the stable thread, but everybody uses their phones differently, have different apps etc, so that's not really saying much either. I for one am not going to switch to the stable channel to find out which is the best.😉
    Arjun_Choudhry and AlejoLinardi like this.
