52
[SURVEY INSIDE] OxygenOS 11 Open Beta 10 for the OnePlus 8 and OnePlus 8 Pro
  1. AlejoLinardi
    Cupcake Jun 3, 2021
    AlejoLinardi , via OnePlus 8 , Jun 3, 2021 :
    I understand that everyone has different use cases, so the only way to compare is that the same person uses both versions. Would be awesome if you could report back your findings!!
    Aaron2017 likes this.
  2. Aaron2017
    KitKat Jun 3, 2021
    Aaron2017 , Jun 3, 2021 :
    If i ever decide to switch channels i'll leave my findings about the battery, but unless they seriously break things in the next beta's i'm gonna stay where i am i think.
    Arjun_Choudhry likes this.
  3. Shubham8550
    Froyo Jun 3, 2021
  4. 777prototype777 likes this.
  5. Aaron2017
    KitKat Jun 3, 2021
    Only if you're willing to wipe all your data and go back to OS10 first. Then you can install this. Other option is to wait for the next beta.
    FFrollaniJr711 likes this.
  6. FFrollaniJr711 , via OnePlus 8 Pro , Jun 3, 2021 :
    I'll wait for the next beta, not worth the wipe.
    Janet_Lainez94 and Aaron2017 like this.
  7. Tee_Eee_Bee
    Ice Cream Sandwich Jun 3, 2021
    Tee_Eee_Bee , Jun 3, 2021 :
    IIRC the build date of the software package you are installing has to be newer than your current version, and the security patch has to be at least the same level or newer.
    So you can swap between the two channels based on that.
    Janet_Lainez94 likes this.
  8. FFrollaniJr711 , via OnePlus 8 Pro , Jun 3, 2021 :
    The two, 11.0.6.6 came out simultaneously and both have may security patch but it will not allow install of OB 10 over 11.0.6.6
  9. Tee_Eee_Bee
    The reason is the build dates:
    OB 10 - 7/05/2021
    11.0.6.6 - 18/05/2021
  10. Tee_Eee_Bee likes this.
  11. Gabby.T
    Froyo Jun 4, 2021
  12. 1+PremWani
    Gingerbread Jun 5, 2021
  13. pavangovind
    Gingerbread Jun 8, 2021
  14. lanks
    Donut Jun 11, 2021
  15. Aaron2017
    KitKat Jun 11, 2021
    Aaron2017 , Jun 11, 2021 :
    No, the stable channel most likely had a fix update in between the normal bi-monthly ones. Next beta should be released between this and the end of the month.(if all goes well of course)
    lanks likes this.
  16. zelos156
    Froyo Jun 17, 2021 at 11:49 AM
    Nuno.Ferreira likes this.
  17. Nuno.Ferreira
    Eclair Jun 17, 2021 at 11:56 AM
    zelos156 likes this.
  18. zelos156
    Froyo Jun 17, 2021 at 12:03 PM
  19. iamincrediblemihai
    Eclair Jun 17, 2021 at 12:21 PM
