54
[SURVEY INSIDE] OxygenOS 11 Open Beta 10 for the OnePlus 8 and OnePlus 8 Pro
  1. Cicala
    Honeycomb Jun 22, 2021
    Cicala , via OnePlus 8 T-Mobile , Jun 22, 2021 :
    Apologize! Won't let it happen again. Very new to all of this.
  2. Aaron2017
    Lollipop Jun 22, 2021
    Aaron2017 , Jun 22, 2021 :
    Search for the open beta 1 thread, you can use the rollback package given in the first post of that thread to switch to the stable channel and go from there to the latest stable update.
    Shailender Sharma likes this.
  3. G_Ziyad_Cheema_UriC , via OnePlus 8 , Jun 22, 2021 :
    I have oxygen updater installed. Can i opt for stable full and downgrade ? It also asks to wipe data and cache. I don't know if i have to wipe data and cache while staying on beta or after going to stable.
  4. Aaron2017
    If you switch to stable you'll have to use the full update, but youl have to download and install the rollback package from the open beta 1 thread first, otherwise it won't work.
  5. G_Ziyad_Cheema_UriC , via OnePlus 8 , Jun 22, 2021 :
    Ok i got it. Downloading the rollback package and after installing it i can update to the latest stable os. Right ?
  6. Aaron2017
    Yep. If the rollback file ends with .jar choose rename and delete that part, it should have .zip at the end.
  7. G_Ziyad_Cheema_UriC , via OnePlus 8 , Jun 22, 2021 :
    Yes it says .jar at the end. I'll rename it before downgrading. One last question, when to wipe data and cache ? Before the tollback or after the tollback ?
  8. Aaron2017
    Switching from beta to stable will wipe all your data anyway. If you want to clear cache you can do it after the update to the latest stable build.
  9. G_Ziyad_Cheema_UriC , via OnePlus 8 , Jun 22, 2021 :
    Ok Sir. Thanks for your time. Cheers.
    Aaron2017 likes this.
  10. Aaron2017
    No worries 👍
  11. Kuba.L
    Cupcake Jun 22, 2021
    Kuba.L , via OnePlus 8 Pro , Jun 22, 2021 :
    Weird.. totally not understandable. After a year you've fixed the overall bugs and problems regarding the flagship product (not everything - my camera still does not open from the double click nor from the lock screen) but it's paid by battery super excessive drainage. Lately before the update from 99 to 80 percent took approximately 3-4 hours. Now after 1h I have 79. I truly hope that fuse with Oppo will bring changes we're waiting for but OnePlus.. for you it might be too late. It will be hard to convince me again to your products.
    Best regards
    Sadly disappointed customer
  12. bpwest80
    KitKat Jun 23, 2021
  13. Adil PM
    Eclair Jul 28, 2021
    Adil PM , via OnePlus 8 , Jul 28, 2021 :
    Now one plus became worst. So you can shift to iphone. When the oxygen os 11 is downloaded many users facing so mony issues including me. If they are going like it i will shift to iphone. I were a one plus fan.
    T1594621353859 likes this.
  14. Tokolozi
    Most Original Avatar Jul 28, 2021
    Tokolozi , Jul 28, 2021 :
    Then just switch? Will be easier for everyone.
    ircfox, Adil PM and Aaron2017 like this.
  15. ArnoldOnePlus8T
    Eclair Jul 29, 2021
