197
[SURVEY INSIDE] OxygenOS 11 Open Beta 2 for the OnePlus 7 and OnePlus 7 Pro
  1. plieka
    Cupcake Feb 7, 2021
    plieka , via OnePlus 7 Pro , Feb 7, 2021 :
    Hi,. I'm trying to install the OB2 download right now but I get a message that the Version I'm trying to install is lower than then OB2
    I have the standard v10
    So how can this message come up for the file "OnePlus7ProOxygen_13.W.56_OTA_0560_all_2101120609_9771858d9b944bdb.zip.jar"
    I removed the .jar so it is now .zip and the local update does see the file but his message comes up
    Any ideas how I can install OB2 on my OP7 Pro?
    Thanks
  2. TomTT
    Gingerbread Feb 7, 2021
    TomTT , Feb 7, 2021 :
    As I've told you before. If you want to install a stable version, you have to wait for a new stable as it can not be older than beta version. Then you can download it from here. But you have to know, that everything will be wiped, so you'll get a new clean installed ROM.
    Good luck
  3. D1571750297416
    Cupcake Feb 7, 2021
    D1571750297416 , via OnePlus 7 Pro , Feb 7, 2021 :
    Hello
    After installing the stable version, will i get regular updates from oneplus directly on my phone?
  4. TomTT
    Thanks for the tip, but as my 10.3.8. version is newer than OB1, I can not update it. Obviously, I'll have to wait on the first OOS 11 Stable version.
  5. Aziz_Raj
    Cupcake Feb 7, 2021
  6. C1603212283180
    Cupcake Feb 7, 2021
  7. reZa7
    Eclair Feb 7, 2021
  8. the beaver
    Cupcake Feb 7, 2021
  9. Murti52
    Eclair Feb 7, 2021
    Murti52 , via OnePlus 7 , Feb 7, 2021 :
    There is no/minimal effect on the battery because of AOD. I'm using it on OnePlus 7 though..!! I love it
    sicfallacy likes this.
  10. Murti52
    Eclair Feb 7, 2021
    It's a normal thing. Don't worry.
  11. Murti52
    Eclair Feb 7, 2021
    Install oxygen updater app and download ob2 from there. I've done the same.
  12. Murti52
    Eclair Feb 7, 2021
    Nope. Data remains intact.
    KaranFafat likes this.
  13. wospino
    Ice Cream Sandwich Feb 7, 2021
    the beaver likes this.
  14. kamehame
    Cupcake Feb 7, 2021
  15. karc
    Cupcake Feb 7, 2021
  16. hot.poison
    Froyo Feb 7, 2021
    hot.poison , via OnePlus 7 , Feb 7, 2021 :
    I also think same. Their updates are very much longer. Really dont know it would be stable or not.
  17. felek73
    Donut Feb 7, 2021
    felek73 , Feb 7, 2021 :
    There is different story at my side..with AOD enabled my battery drain has doubled in standby
  18. the beaver
    Cupcake Feb 7, 2021
