173
[SURVEY INSIDE] OxygenOS 11 Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. Abdul B.
    OxygenOS Operations Staff Member Feb 5, 2021
    Abdul B. , Feb 5, 2021 :
    Edit: For those that were using Android 11 Open Beta 2, please provide your feedback through this survey
    Hey everyone,
    Here are the latest open beta builds based on Android 11 for the OnePlus 7T and OnePlus 7T Pro!
    Please bear in mind that this is beta software and, as such, may be less stable than stable MP builds. If you are installing this build, we highly recommend you make a full system back-up before proceeding. We also recommend you read all the instructions and notes before proceeding.
    Changelog
    • System
      • Optimized the sliding effect of the dynamic wallpaper
      • Improved power consumption in some scenarios
      • Optimized the adjusting intensity of automatic brightness to bring a more smooth using experience
      • Fixed the issue with the adapter not charging and using the headset at the same time
      • Fixed the issue in which the battery icon is not displayed on the status bar
      • Fixed the issue that 'Tips & Support' is not displayed in the Settings
    • Camera
      • Fixed the small probability flashback issue with the camera when unlocking in professional mode
    • Ambient Display
      • Newly supported Always-on ambient display feature for OP7Pro and OP7TPro (Go to: Settings - Utilities - OnePlus Laboratory - Always-on ambient display)
    Note:
    Enabling the AOD feature will lead to increased power consumption in the build. However, this will be optimized in the upcoming builds.
    Please keep in mind that this is beta software. These builds are sometimes not as stable as our official OTAs generally are. By installing this update, you accept the potential risks. For those who were on previous versions for OnePlus 7T and OnePlus 7T Pro, we appreciate your active feedback and for reaching out to us. With your help, we have been able to better optimize and improve several key areas. Thank you for your patience and as always, we look forward to getting your continued feedback via the Community app.
    If you don't have the Community app installed on your device, feel free to download it HERE. You can check here for more information on the integrated Feedback tool.
    Please note:
    • If you have already flashed an Open Beta (you are currently running the latest Open Beta), you will receive this new build as an OTA.
    • If you are not running open beta software and would like to, please refer to the flashing instructions and the full ROM on the downloads page here.
    • Once you migrate to the Beta path, you will continue to receive Open Beta OTAs. You will no longer receive the regular Official Stable OTAs.
    • Moving back to the Official OTA path from the Beta path will require a full install and clean flash (full wipe of all data and cache).
    Make sure to let us know how you feel about the beta builds here in the thread too. We are watching.
    Never Settle.
  2. dVader
    Eclair Feb 5, 2021
  3. nigel.john97
    Cupcake Feb 5, 2021
    nigel.john97 , Feb 5, 2021 :
    Quick Question, if I'm still running OOS 10 and if I want to shift to the Open beta program Can I directly just download the Open Beta 2? or there are other steps involved.
  4. Kalyan Rao D
    Cupcake Feb 5, 2021
  5. WEBSDCOOL
    Gingerbread Feb 5, 2021
  6. Aswin08
    Honeycomb Feb 5, 2021
  7. Honey_6
    Cupcake Feb 5, 2021
  8. Yash Pratap Singh.
    KitKat Feb 5, 2021
    vinothraaja, Gs_Rabbi, selimm and 3 others like this.
  9. Swetanshu@200 , via OnePlus 7T Glacier Blue , Feb 5, 2021 :
  10. bprrkl
    bprrkl , via OnePlus 7T , Feb 5, 2021 :
    Yes u can directly download and install
    AzureB1te likes this.
  11. #11
  12. QuintinG
    Eclair Feb 5, 2021
    QuintinG , Feb 5, 2021 :
    So, quick question. Will the AOD feature be coming to the OP7T? Or is this to only be a "pro" feature?
    Thanks!
  13. xfuryred
    Eclair Feb 5, 2021
  14. G_Yury_Koltsov_KwaQ
  15. Saikumar7
    Ice Cream Sandwich Feb 5, 2021
    Saikumar7 , Feb 5, 2021 :
    It will come for op7 & op7t aswell but for now it's not there..!
  16. Swetanshu@200 , via OnePlus 7T Glacier Blue , Feb 5, 2021 :
    Hey mate it's present in the oneplus laboratory section. May be after some updates it may come to stable at the end.
    Finger crossed 🤞
  17. Mr_Inju
    Donut Feb 5, 2021
  18. Aswin08
    Aswin08 , Feb 5, 2021 :
    Are you able to confirm it yourself?
    If not, on what basis?
    Why would stable to beta wipe all your data?
    It won't.
  19. Nishant_Ramteke
    Froyo Feb 5, 2021
  20. Flavioadnap
    Donut Feb 5, 2021
    Flavioadnap , via OnePlus 7T , Feb 5, 2021 :
    in the future it will also arrive for 7 and 7t
    Chanyeong Lim and AzureB1te like this.
