173
[SURVEY INSIDE] OxygenOS 11 Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. EvenSnow
    Cupcake Feb 5, 2021
    EvenSnow , Feb 5, 2021 :
    camera app wiping data cache and restart. not working :(
  2. MattHayesRVA
    Eclair Feb 5, 2021
    MattHayesRVA , Feb 5, 2021 :
    Not going to bother factory resetting after not working in OB1. Not going through all that setup again.
    Just out of curiosity, what carrier are you on? I am on Google Fi.
    I also am not able to use RCS "chat" in Google Messages. I have chatted with Google Fi and they said this is a known issue and are working on a fix.
    CarterD13 likes this.
  3. Nick_Amina
    Froyo Feb 5, 2021
    Nick_Amina , Feb 5, 2021 :
    Before beta 1, OxygenOs 11, the resolution of the pictures was 1824 x 4000, Now after the update all I would try is 960 x 2080. Can something be done about it, or do we have to use other applications? Thanks!
  4. sameeh
    Gingerbread Feb 5, 2021
    sameeh , via OnePlus 7T , Feb 5, 2021 :
    Never heard about Google FI
  5. MattHayesRVA
    Eclair Feb 5, 2021
    Where are you located? Google Fi is U.S. only.
  6. sameeh
  7. ghostofcain
    Marshmallow Feb 5, 2021
    ghostofcain , Feb 5, 2021 :
    factory reset then
  8. jayu02
    Cupcake Feb 5, 2021
    jayu02 , via OnePlus 7T Pro , Feb 5, 2021 :
    I am sending a screenshot You will find it different.....
    I did not have that much space red sketched above.....
    I hope you have understood.... Solve soon happy #oneplus
    #onelusisgreat 🙏🙏
  9. sameeh
    May be they are planning to get new features
    jayu02 likes this.
  10. Last edited by a moderator: Feb 6, 2021
  11. T1591261470301
    Cupcake Feb 5, 2021
    T1591261470301 , via OnePlus 7T , Feb 5, 2021 :
    Yes, you have to install oxygen updater and turn on advanced mode ,then you should select update method( open beta full) and you can install the obt2 and enjoy the features.😎
  12. T1591261470301
    Cupcake Feb 5, 2021
  13. Aaron2017
    Lollipop Feb 5, 2021
    Aaron2017 , Feb 5, 2021 :
    I don't know if it was like that before,but it's the same on the 8 pro running stable OOS11 so i guess it'll stay that way
  14. Bharatrules
    Cupcake Feb 5, 2021
    Bharatrules , via OnePlus 7T , Feb 5, 2021 :
    I have this system icon bug, which is white everytime in dark as well as in white theme
    Looks irritating eveytime open setting panel
    Please Help!!!
  15. psykd420
    Donut Feb 5, 2021
  16. Esohail
    Cupcake Feb 5, 2021
  17. J.Vokbirg , via OnePlus 7T Pro McLaren Edition , Feb 5, 2021 :
    Быстрая Камера (нажатие 2 раза на клавишу питания) не работает. Точнее работает вполовину, камера запускается, но не делает фото автоматически!!!
    [deepl translation added by moderator]
    Quick Camera (press 2 times on power key) does not work. More precisely, it works halfway, the camera starts but does not take a photo automatically!!!!
  18. sameeh
  19. Esohail
    Cupcake Feb 5, 2021
  20. sameeh
