173
[SURVEY INSIDE] OxygenOS 11 Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. Au_Di
    Eclair Feb 5, 2021
    Au_Di , Feb 5, 2021 :
    open beta 1 do not wipe your data but this ob2 it will
    backup your data first
  2. godzinilla
    Eclair Feb 5, 2021
  3. dEb_OP7T
    Eclair Feb 5, 2021
    dEb_OP7T , via OnePlus 7T , Feb 5, 2021 :
    You kept it in the root directory right?
  4. babaak
    Eclair Feb 5, 2021
  5. premchandra1993
    Gingerbread Feb 5, 2021
  6. dEb_OP7T
    Eclair Feb 5, 2021
    babaak likes this.
  7. babaak
    Eclair Feb 5, 2021
    babaak , via OnePlus 7T , Feb 5, 2021 :
    Thanks for your quick replies
    dEb_OP7T likes this.
  8. dEb_OP7T
    Eclair Feb 5, 2021
    babaak likes this.
  9. pedritopl
    pedritopl , Feb 5, 2021 :
    Yes, I did. Standard procedure. No problems.
    That's almost correct. I would put it this way to be exact:
    - make sure "Automatic system updates" option is disabled in Developer options
    - disable/uninstall modules
    - reboot
    - install OTA update
    - install Magisk to inactive slot
    - reboot to recovery
    - clear cache
    - reboot to system
    - install modules
    Important! If You use the module for enabling the native call recording this has to be removed and installed from scratch after update. Do not just disable/enable this module as it modifies the Phone apk during the installation process. You don't want to replace your OB2 Phone apk with the OB1 Phone apk by mistake :)
    sameeh likes this.
  10. hamvaspeter
    Eclair Feb 5, 2021
  11. Kerkdriel_Online
    Ice Cream Sandwich Feb 5, 2021
  12. pedritopl
    Snoopimanov, hamvaspeter and ssagheer like this.
  13. sameeh
    hamvaspeter and razaransari18 like this.
  14. carltech515 , via OnePlus 7T Frosted Silver , Feb 6, 2021 :
    yeah please implement the black mode.
  15. razaransari18 likes this.
  16. razaransari18
    Froyo Feb 6, 2021
  17. sameeh
    Gingerbread Feb 6, 2021
  18. razaransari18
    Froyo Feb 6, 2021
  19. SAPMAS
    Cupcake Feb 6, 2021
  20. sameeh
