173
[SURVEY INSIDE] OxygenOS 11 Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. p2p
    Honeycomb Feb 6, 2021
    p2p , Feb 6, 2021 :
    I think that is the proximity sensor
    WAQUAR_ALAM likes this.
  2. Depth_47
    Donut Feb 6, 2021
  3. Nikola Mirko
    Cupcake Feb 6, 2021
    Nikola Mirko , via OnePlus 7T , Feb 6, 2021 :
    Hi guys have are you? I have One plus 7T.
    I'm download zip file with new Oxygen OS Beta 2 and copy in may storage phone and I doing everything what you said....
    I can't install . Thanks for help
    I send my pictures
    Kind Regards
    Nikola😊
  4. Durgesh1494
    Cupcake Feb 6, 2021
    Durgesh1494 , via OnePlus 7T , Feb 6, 2021 :
    Can someone help me..
    I am on stable oneplus 7t India 10.3.8 and when i download zip of opwn beta 1 and uodate through local storage it say not allowed to downgrade. Existing version is higher.. what to do.. how to install open beta after 10.3.8
  5. jatin0990
    Gingerbread Feb 6, 2021
    jatin0990 , via OnePlus 7 , Feb 6, 2021 :
    Bcz stable version in latest one thts y u r not able to install
  6. Aaron2017
    KitKat Feb 6, 2021
    Aaron2017 , Feb 6, 2021 :
    Are you sure you downloaded the OB2 file and not the OB1?
    R1575229986832 likes this.
  7. Nikola Mirko
    Cupcake Feb 6, 2021
  8. ToggoKun
    Donut Feb 6, 2021
  9. MrDJ83
  10. Nikola Mirko
    Cupcake Feb 6, 2021
  11. H1612258370035
    Cupcake Feb 6, 2021
    H1612258370035 , via OnePlus 7T , Feb 6, 2021 :
    Скачал , но проблема с нагревом и разрядкой батареи во время игр так и осталась , начала тормозить разблокировка по лицу
  12. Durgesh1494
    Cupcake Feb 6, 2021
  13. nandPlus
    Donut Feb 6, 2021
    nandPlus , via OnePlus 7T Pro , Feb 6, 2021 :
    Yupp! I have been facing the same issue and have shared the feedback and logs. I sadly couldn't go any longer without being able to answer, and I tried a reset. That didn't help. So I finally rolled back to stable release of oxygen os 10. It's the first time that I had no choice but to rollback to stable in these many years of open beta (since OnePlus 5 days), but that's what I signed up for being on open beta! :) Happy to have contributed to the community!
    gurudrew likes this.
  14. Vitamin86
    Eclair Feb 6, 2021
    Vitamin86 , Feb 6, 2021 :
    при разблокировке экрана кнопкой или двойной мигает зеленая точка внизу и справа от камеры. что это?
  15. J.Vokbirg
    Donut Feb 6, 2021
  16. J.Vokbirg
    Donut Feb 6, 2021
    J.Vokbirg , via OnePlus 7T Pro , Feb 6, 2021 :
    Привет всем! Помогите пожалуйста !! была Оксиджен 10, накатил Бэта 11, как вернуться на стабильную 10?
  17. nandPlus
    Donut Feb 6, 2021
    The downgrade instructions are present in the oxygen os 11 open beta 1 post. There are links to stable build. Do note: you'll lose all your data when you downgrade. Make sure you have backed up your data.
    sameeh likes this.
