173
[SURVEY INSIDE] OxygenOS 11 Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. asifwanderlust
    Gingerbread Feb 7, 2021
    Chiranjit Das likes this.
  2. J1577193114745
    Cupcake Feb 7, 2021
    J1577193114745 , via OnePlus 7T , Feb 7, 2021 :
    1)
    My phone shifts from 90hz to 60hz randomly.
    Then I have to go to settings and play with the refresh rate setting a bit to get it back on 90hz
    2)
    Battery is charging slowly on my warp charge.
    It was quicker with stable version of Android 10.
    3)
    Battery draining a bit faster on this beta.
    hamvaspeter likes this.
  3. ifhamb
    Eclair Feb 7, 2021
  4. Fotoklasika
    Froyo Feb 7, 2021
    Fotoklasika , via OnePlus 7T , Feb 7, 2021 :
    Whats good:
    *Fast overall performance with apps and gamea on Oxygen 11 said:
    *Fast 4G+ LTE speeds
    *Fixed brigtness manual control (Oneplus 8T still is that issuse). Thanks Beta 2!
    What Need To Fix on Beta 3:
    *Still can't recognize Wifi adapter real speed link (driver problem), still slow download speed after oxygen 11 beta 1 update (upload is fast)
    *no January Security Patch
    *no Always On Display
    Waiting beta 3 on 2021.02.20 (With Fast Wifi download speed and February Security Patch
  5. tanveer.ansri70
    Cupcake Feb 7, 2021
    tanveer.ansri70 , via OnePlus 7T , Feb 7, 2021 :
    1. Lockbox files disappeared after update.
    2. 90Hz Refresh Rate not working properly in some apps.
    3. Comfort vision not working properly If typing anything.
    kanebckuu and Turbofotografas like this.
  6. Aaron2017
    Lollipop Feb 7, 2021
    Aaron2017 , Feb 7, 2021 :
    1) you can try wiping your phone cache, might help with that,if not,you can report it via feedback section.
    2)have you tried it with optimised charging turned off?
    3)the wipe cache may also help with this,if not you can also report it via feedback section.
    Neitred likes this.
  7. Fotoklasika
    Froyo Feb 7, 2021
    me to. Check your wifi speed...Upload will be faster
    kanebckuu likes this.
  8. Rakesh_Jay
    Donut Feb 7, 2021
    Rakesh_Jay , via OnePlus 7T , Feb 7, 2021 :
    Finally i downloaded the Android 10 stable version from another website and also updated to the latest security patches from OnePlus!
    asifwanderlust likes this.
  9. W1574180452296
    Cupcake Feb 7, 2021
  10. Indianpacific
    Cupcake Feb 7, 2021
    Indianpacific , via OnePlus 7T , Feb 7, 2021 :
    Mobile data is working fine for me in the lastest build. Not experiencing any issues.
  11. Aaron2017
  12. MarshaLOP
    MarshaLOP , via OnePlus 7T , Feb 7, 2021 :
    Yeah ik, they have mentioned it. I was just sarcastically saying that if there is no OnePlus laboratory, how come is he able to turn aod on OnePlus 7t.
  13. Kunnu_111
    Cupcake Feb 7, 2021
  14. JiyaDeenRashi
    Donut Feb 7, 2021
  15. C1574521417452
    Cupcake Feb 7, 2021
  16. siddhestroy
    Cupcake Feb 7, 2021
    siddhestroy , via OnePlus 7T , Feb 7, 2021 :
    Download directly
  17. Neitred , via OnePlus 7T Pro McLaren Edition , Feb 7, 2021 :
    Use the feedback button.
    ghostofcain likes this.
  18. Aaron2017
    File a report through the feedback section.
