173
[SURVEY INSIDE] OxygenOS 11 Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. AmitRao23
    Gingerbread Feb 7, 2021
    AmitRao23 , via OnePlus 7T , Feb 7, 2021 :
    Read instructions on the OnePlus site.
  2. WEBSDCOOL
    WEBSDCOOL , via OnePlus 7T , Feb 7, 2021 :
    So, this build is good. Many bugs encountered in OB1 have been fixed in this build except battery stats bug. The Battery stats reset only at a minimum charge of 99% which wasn't the case on OOS10.
  3. Chiranjit Das
  4. Chiranjit Das
    Chiranjit Das , via OnePlus 7T , Feb 7, 2021 :
    You can download from here..👇🏻 it's working
    https://www.androidsage.com/2021/02...11-open-beta-2-for-oneplus-7-7-pro-7t-7t-pro/
  5. Chiranjit Das
  6. Chiranjit Das
  7. Chiranjit Das
  8. A1581949983022
    Cupcake Feb 7, 2021
    A1581949983022 , Feb 7, 2021 :
    From yesterday my oneplus 7t pro is occasionally brinks and a purple line on right side of the screen arrived.
  9. khushil513
    Cupcake Feb 7, 2021
    khushil513 , Feb 7, 2021 :
    I did local upgrade of Beta 2 from stable firmware, but I am stuck on boot screen, If i choose reboot option it is rebooting to the same menu.
    It is showing this:
    Boot Reason: fs_mgr_mount_all
    Unable to parse kernel log. For more informaton,
    adb pull /mnt/vendor/op2/rbr_log
    or pull op2.img
    Please help if you know the solution :)
  10. sameeh
    sameeh , via OnePlus 7T , Feb 7, 2021 :
    Yeah,I thought they gonna fix it in OB2 but unfortunately they didn't
    WEBSDCOOL likes this.
  11. CarterD13
    Donut Feb 7, 2021
  12. MarshaLOP
    MarshaLOP , via OnePlus 7T , Feb 7, 2021 :
    Loved the way the Spotify widget is arranged in the notification panel, looks clean and minimal. And the touch animations are really mesmerizing while pausing and changing the song from the notification.
  13. khushil513
    Cupcake Feb 7, 2021
    Update: Somehow I managed to boot my phone up, but it was booted in the stable version from which I flashed beta files
    Can anyone wxplain me why this happned...
  14. joseph.nevin
    Cupcake Feb 7, 2021
  15. D1600610555193
    Honeycomb Feb 7, 2021
  16. Neitred , via OnePlus 7T Pro McLaren Edition , Feb 7, 2021 :
    Try to use the feedback button for this info. That is something OP sees. Their not in this thread.
  17. sameeh
    Clear the cache and reboot your device
  18. joseph.nevin
    Cupcake Feb 7, 2021
  19. Chandraprakash9
    Froyo Feb 7, 2021
