173
[SURVEY INSIDE] OxygenOS 11 Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. Being7t
    Donut Feb 8, 2021
    _Vinod_Bg_ likes this.
  2. babaak
    Eclair Feb 8, 2021
    babaak , via OnePlus 7T , Feb 8, 2021 :
    If i revert back to os10 will i be getting OP security updates and later official 11 ? Currently in OB1 and it seems i am not getting OB2 from system update and i couldn't install it via local upgrade from OS updater because its showing no zip file even if I put OB2 file in root directory.
    Anyone else with the same issue?
    I have indian version HD1901
  3. @SiddharthSaxena
    Cupcake Feb 8, 2021
    @SiddharthSaxena , via OnePlus 7T , Feb 8, 2021 :
    Appreciate the beta update. There are few bugs in here, with this update phone is getting discharged very quickly and fast changing is gone at all with this update. Also the minor one double tab to wake the device up is no more working.
  4. us4ak
    Froyo Feb 8, 2021
    us4ak , via OnePlus 7T Pro , Feb 8, 2021 :
    Did you try the following?
    Move the file to Internal Storage -> Rename (filename should end with extension '.zip')
    System Settings -> System Updates -> Local upgrade
  5. babaak
    Eclair Feb 8, 2021
    Yup tried that already. but it doesn't shows up
  6. Aung Khant Kyaw
    Froyo Feb 8, 2021
    Lemillion likes this.
  7. sameeh
    Gingerbread Feb 8, 2021
  8. Niyskiy
    Cupcake Feb 8, 2021
  9. Aravind_ar7
    Cupcake Feb 8, 2021
  10. Kunalb7 likes this.
  11. MD.Khan
    Froyo Feb 8, 2021
    Aung Khant Kyaw likes this.
  12. SarinKoodali
    Donut Feb 8, 2021
  13. Aung Khant Kyaw
    Froyo Feb 8, 2021
  14. Aung Khant Kyaw
    Froyo Feb 8, 2021
    MD.Khan likes this.
  15. SarinKoodali
    Donut Feb 8, 2021
    SarinKoodali , Feb 8, 2021 :
    stable 10.3.8 . I want to install 11 beta. but we can't install it in McLaren
  16. Aaron2017
    Lollipop Feb 8, 2021
    Aaron2017 , Feb 8, 2021 :
    I don't know about that,used it many times myself in the past,without any problems.in fact,if you read the the faq stable/beta guide for the 7/t series it get's mentioned that you can use it if you want updates faster if my memory serves me right
  17. sameeh
    sameeh , via OnePlus 7T , Feb 8, 2021 :
    Never heard about that,but I know in fact too many users updates their phones through oxygen updater
    Whatever works for you man
  18. Chiranjit Das
  19. Aung Khant Kyaw
    Froyo Feb 8, 2021
    Aung Khant Kyaw , via OnePlus 7T , Feb 8, 2021 :
    Thanks for answering mate.
    I really appreciate.
  20. Chiranjit Das
