173
[SURVEY INSIDE] OxygenOS 11 Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. Donald Nice
    Honeycomb Feb 8, 2021
    Donald Nice , Feb 8, 2021 :
    So now that you are a beta tester, you did your homework and used the feedback button to report the bug and help the devs to fix it, didn't you?
    Neitred and Chiranjit Das like this.
  2. Chiranjit Das
    Gingerbread Feb 8, 2021
    Chiranjit Das , via OnePlus 7T , Feb 8, 2021 :
    Sure👍🏻
    Donald Nice likes this.
  3. ShreeshailSU
  4. Aaron2017
    Lollipop Feb 8, 2021
    Aaron2017 , Feb 8, 2021 :
    If you already tried the possible solutions given in this thread you can report it via feedback,they're not going to no about otherwise
    ghostofcain likes this.
  5. Aaron2017
    Are you sure you gave it through the proper channel?reproduced the issues,recorded and share the logs?i ask because i don't see the benefit a moderator would gain by deleting your feedback
  6. ghostofcain
    Marshmallow Feb 8, 2021
    ghostofcain , Feb 8, 2021 :
    Follow the instructions in the OP of this thread using the OP7T Pro build.
  7. Nafice1
    Eclair Feb 8, 2021
    Nafice1 , via OnePlus 7T Pro , Feb 8, 2021 :
    Select your country to france at download page.
  8. sameeh
    sameeh , via OnePlus 7T , Feb 8, 2021 :
    profytroll said:
    hello here I have oneplus 7t HD1900 of 8/264 go and I live in France which version of the beta of oxygen os 11 should I take?
    Please.
    Europe
  9. I1606918790316
    Cupcake Feb 8, 2021
  10. I1606918790316
    Cupcake Feb 8, 2021
  11. Aaron2017
    The changelog in the original post says only for 7t pro,so no.7t should get it in upcoming builds
  12. Shaikhfaisalm
    Eclair Feb 8, 2021
  13. zedd08
    Cupcake Feb 8, 2021
    zedd08 , via OnePlus 7T , Feb 8, 2021 :
    Package manager is unable to install any 3rd party apps. It prompts for the install, goes to about 90% and then crashes. Play store is able to install apps
  14. sarath1987
    Cupcake Feb 8, 2021
  15. Tanvir_Mahmood
    Cupcake Feb 8, 2021
    Tanvir_Mahmood , via OnePlus 7T , Feb 8, 2021 :
    In little low light condition, light sensor detects as if it's in pocket, that's why ambient display doesn't work. Light sensor calibration should be improved
  16. RAMEEZA2K15
  17. I1575292979361
    Cupcake Feb 8, 2021
  18. Aaron2017
    Have you tried disabling optimised charging?
  19. SarinKoodali
    Donut Feb 8, 2021
    SarinKoodali , Feb 8, 2021 :
    can't understand
