173
[SURVEY INSIDE] OxygenOS 11 Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. forslaey
    Cupcake Feb 8, 2021
  2. MarshaLOP
    Gingerbread Feb 8, 2021
    MarshaLOP , via OnePlus 7T , Feb 8, 2021 :
    Found a new bug. Open YouTube and play a video. Then pause the video and switch of the display by tapping power button. Then unlock the phone, you'll notice that the display is refreshing at 60hz but in the settings it showing 90hz.
  3. joseph.nevin
    Cupcake Feb 8, 2021
  4. Chiranjit Das
    Chiranjit Das , via OnePlus 7T , Feb 8, 2021 :
    open Oxygen Updater App settings >> Select OP7TPro India >> Mark Incremental Update option.
    before that confirm the Model No. then you will get the next update 🙂
  5. Aaron2017
    Lollipop Feb 8, 2021
    Aaron2017 , Feb 8, 2021 :
    You could try clearing your phone cache,and worst case scenario,factory reset,if it really bothers you
    ghostofcain likes this.
  6. Prasenjit20
    Eclair Feb 8, 2021
  7. Chiranjit Das
    @Abdul B.
    Beta 2 update done, but....
    1. OnePlus Laboratory has gone.
    2. Battery full charging time takes 1Hr. 20Min.
    3. Weather auto detection not working sometimes.
    4. Sometimes system application lagging.
    5. Security Update need to update (still shows Dec,2020)
    6. No AOD (Always On Display for 7/7T device)
    7. Fonts need to Change, its too much narrow, sometimes nothing to see anything 🤦🏻
    please bring back OOS10 font.
    8. Please launch OnePlus Dex like Samsung Dex
    9. OnePlus Recorder app need to fix, there has nothing to show any recordings which has stored in memory.
    10. kindly update regarding Notification Light on front camera.
    11. Keyboard One-handed mode still not come.
    12. Error during calls in hold, unable to Merge sometimes.
    13. Gallery photo loads in every time when Open the App; loading time is too much slow.
    suck☹️ please fix it in Subsequent Beta.
  8. ShEV_T
    Donut Feb 8, 2021
    Niyskiy likes this.
  9. Chiranjit Das
    open Oxygen Updater App settings >> Select OP7T India >> Mark full update option.
  10. Aaron2017
    You have to report it via the feedback tool and share the logs with them if you want them to fix all your issues.they're not going to know about it otherwise
    bprrkl and ghostofcain like this.
  11. Chiranjit Das
    I'm unable to post feedback, shows Server Error during post.
  12. Aaron2017
    Did you try the + button on the homepage?that has always worked for me.
  13. Chiranjit Das
    Bro, I'm not a Novice. I did try that from morning to now but no luck.
    thanks for your advice 👍🏻
    aaronpe likes this.
  14. ghostofcain
    Marshmallow Feb 8, 2021
    ghostofcain , Feb 8, 2021 :
    Probably as well, to factory reset prior to reporting bugs, it's the only way you can guarantee that the bug is due to the update, especially with beta builds.
    B k likes this.
  15. bhojanepratik
    Froyo Feb 8, 2021
    bhojanepratik , via OnePlus 7T , Feb 8, 2021 :
    I would rather see the time with just a glance at my phone when it's lying on the table. Especially while working.
    But afterall it's a matter of preference :)
    Bennov likes this.
  16. Last edited by a moderator: Feb 11, 2021
    Angel1297 and Nishant_Ramteke like this.
  17. Aaron2017
    Your welcome,even though it clearly wasn't needed.
  18. Suv94.
    Froyo Feb 8, 2021
  19. djorghios likes this.
  20. Aaron2017
    As mentioned several times on this thread,nobody here can answer that because nobody here knows.
