173
[SURVEY INSIDE] OxygenOS 11 Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. Oksygen
    Gingerbread Feb 9, 2021
    Oksygen , via OnePlus 7T , Feb 9, 2021 :
    At Play Store.
    You need to read a bit before posting here. I will not recommend you to update if you don't know what you are doing. Wait for the stable version.
    Donald Nice and ghostofcain like this.
  2. Aaron2017
    KitKat Feb 9, 2021
    Aaron2017 , Feb 9, 2021 :
    If believe some links where already given in this thread,or you can download the app Oxygen updater from the playstore and get it through there.
    ghostofcain likes this.
  3. O1609756229805
    Cupcake Feb 9, 2021
  4. O1609756229805
    Cupcake Feb 9, 2021
  5. Aaron2017
    KitKat Feb 9, 2021
    In the app settings enable advanced mode,select open beta full update and you should be able to download it.
  6. rmstrasel
    Froyo Feb 9, 2021
  7. O1609756229805
    Cupcake Feb 9, 2021
  8. ghostofcain
    Marshmallow Feb 9, 2021
    ghostofcain , Feb 9, 2021 :
    Look if you're struggling to download how are you going to cope with the potential issues with the beta, as has been said before I would recommend you stick with the stable build.
    aaronpe likes this.
  9. ghostofcain
    And what where you doing in those 25 minutes? I assume you've given it at least four full charge cycles to settle, then factory reset, and waited a further 4 charges cycles before reporting it as an issue?
    aaronpe likes this.
  10. O1609756229805
    Cupcake Feb 9, 2021
    O1609756229805 , via OnePlus 7T , Feb 9, 2021 :
    If there is I will change to android 10
  11. Aaron2017
    KitKat Feb 9, 2021
    Be sure you know what you're getting into,it's beta and there always a risk of potential bugs,and misbehaviour,and many seem to occur on the 7t in particular,judging by the posts made on this thread
  12. O1609756229805
    Cupcake Feb 9, 2021
    So if there is I will switch to 10 again
  13. O1609756229805
    Cupcake Feb 9, 2021
  14. Aaron2017
    KitKat Feb 9, 2021
    Allright,if it should come to that be sure to report the bugs before you switch,so they can sort them out for future builds.
  15. O1609756229805
    Cupcake Feb 9, 2021
  16. Oksygen
    If you are having problems on finding and installing beta 2, you will have even more problems rolling back to 10. You are a novice and should not use beta software. Just my opinion and advice...
    stovo06 and Donald Nice like this.
  17. Aaron2017
    KitKat Feb 9, 2021
    That's personal preference,some might like the new style while others don't.
  18. Q1612873100153
    Cupcake Feb 9, 2021
  19. ce_franck and PriyeshPatil like this.
  20. godzinilla
    Eclair Feb 9, 2021
    godzinilla , via OnePlus 7T Pro , Feb 9, 2021 :
    Battery performance with enabled AOD is poor, I've managed to get about 24 hours of usage with 3:30 SOT, when on OpenBeta 1 with Ambient Display these times were doubled. OP7TPRO.
    ce_franck likes this.
