173
[SURVEY INSIDE] OxygenOS 11 Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. wasihw
    Cupcake Feb 10, 2021
    wasihw , Feb 10, 2021 :
    how many days it will tool to releasing new stable version on OS11 to all 7 series phones
  2. ghostofcain
    Marshmallow Feb 10, 2021
    ghostofcain , Feb 10, 2021 :
    Why are you waiting, bet your 15000rs phone isn't as good as my OP7T whether it's running android 11 or not, if is it beggars the question why you spent all that money on an OP7T in the first place.
    So has the OP7T, I'm not sure what your point is.
    No one knows. Fair guess, it'll be less than 365.
    aaronpe likes this.
  3. S1570877226650
  4. ghostofcain
    Is that after you've followed the advice in this thread?
    aaronpe likes this.
  5. S1570877226650
  6. ghostofcain
    I'm not sure what having your bootloader locked has to do with it, though?
  7. ghostofcain
    Sorry? That doesn't excuse you from READING. Advice on slow charging issue is in both this and the OB1 thread, read them and try the solutions suggested for YOUR issue
    aaronpe likes this.
  8. haresh.swain
    Donut Feb 10, 2021
  9. Yuuna
    Yuuna , Feb 10, 2021 :
    Can't install the Open Beta 1, it says the Open Beta version is too low to install.
    Got the OS 10.0.16 for the 7T.
    Any ideas?
  10. surajde16
  11. Aaron2017
    Lollipop Feb 10, 2021
    Aaron2017 , Feb 10, 2021 :
    Yes,install OB2.OB1 is a lower build then the one you're currently running
  12. Aaron2017
    I don't think that's an issue,it's the same on the 8 pro so i think that's just the new style of android 11
  13. Yuuna
    How to install OB2? They said in the thread to install go to the OB1 Installation?
  14. CapturedByKen
    ani257 and SAPMAS like this.
  15. ghostofcain
    The instructions on installing the OB can be found in the OP of the OB 1 thread, just substitute OB2 file. If you are struggling to get the beta installed are you ready for the potential consequences of getting it installed?
    aaronpe likes this.
  16. Aaron2017
    Several people posted some of the links in this thread,you may have to scroll back a bit though.or use the Oxygen updater app
    ghostofcain likes this.
  17. Chiranjit Das
    Gingerbread Feb 10, 2021
    Chiranjit Das , via OnePlus 7T , Feb 10, 2021 :
    It's so true, next will move to Google or Samsung..☹️
    keep in mind, you never get this kind Smooth Experience to any other brands. 👍🏻
    Katrick likes this.
  18. Akhil0199
  19. Katrick likes this.
  20. ghostofcain
    READ this very thread, and the way will be clear.
    Of course you've done a factory reset?
