173
[SURVEY INSIDE] OxygenOS 11 Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. sameeh
    Gingerbread Feb 10, 2021
    sameeh , via OnePlus 7T , Feb 10, 2021 :
    You can download from oxygen updater if you can't wait
    Akhil Madiri likes this.
  2. Katrick
    Honeycomb Feb 10, 2021
    Katrick , via OnePlus 7T , Feb 10, 2021 :
    No it hasn't I am also running 11 beta , m31 has received stable,.
  3. dbltap
    Donut Feb 10, 2021
    dbltap , via OnePlus 7T Pro , Feb 10, 2021 :
    Thanks for the confirmations from all who replied.
    I'm going to try a rollback and I'll report back on the widevine status once complete.
    Sounds like a similar issue to the 8T/8 series updates. Only affecting some devices. I've logged the bug via the official channels.
    For anyone affected, I'll post updates in this thread.
    pedritopl and Rajesh_Mech like this.
  4. Rajesh_Mech
    Cupcake Feb 10, 2021
    Rajesh_Mech , via OnePlus 7T , Feb 10, 2021 :
    I too lost my widevine support. It has downgraded to L3 after the beta. Went back to OOS 10 still cannot get back the L1 support. Did a lot of recommended fixes from the community member but nothing helped finally from the Customer care side they asked me to go to the Service Center that's the only way to fix.
  5. vaibs101
  6. Aaron2017
    KitKat Feb 10, 2021
    Aaron2017 , Feb 10, 2021 :
    You probably did so yourself,but i'm gonna put it out there anyway,but i did a phone cache wipe after installing OB1 and OB2.don't know if that's why mine is L1 but maybe worth a try before going back to OOS10,if you haven't already tried it
    Abhilash995 likes this.
  7. sameeh
  8. 1+1oneplus
    Donut Feb 10, 2021
    x X x likes this.
  9. X1570717455902
  10. Aaron2017
    KitKat Feb 10, 2021
    You can use Oxygen updater from the playstore or one of the several links that's been given earlier on this thread.
  11. sameeh
    Disable it and see if the battery is holding the charges.
  12. ghostofcain
    Marshmallow Feb 10, 2021
    ghostofcain , Feb 10, 2021 :
    In my experience ultra power saving modes disable AOD for this exact reason. Why not cut out the middle man and disable AOD yourself?
  13. dbltap
    Donut Feb 10, 2021
    Thanks, I tried pretty much everything to get it back to L1 but nothing helped. I rolled back to 10 and it's still on L3.
    As OnePlus have had issues like this before, I think it must be down to the update process going wonky somewhere.
    Got in touch with chat and after a few attempts, they suggested a remote connection to diagnose (?)
    I'm hoping they can fix whatevers gone wrong with the keys. If not, I'll have to send it off to the service centre.
  14. Jadhav27
    Jadhav27 , Feb 10, 2021 :
    I have updated it with the zip file and still it's same Android 10, are there any steps to follow ?
  15. Aaron2017
    KitKat Feb 10, 2021
    Yeah,i thought as much,but posted anyway,just in case.yeah,from what i read on both this and the 8 series thread they seem to have problems with that,a lot of people stuck on L3.luckily,and strangeley enough,both my 7t pro and my wife's 8 pro had L1 all along the line,so maybe it's a region based thing or something that goes wrong with the update.
  16. Aaron2017
    KitKat Feb 10, 2021
    Which exact zip file did you download?
  17. Jadhav27
    the one on the site, they asked to download a zip file for 7t on a computer and then share it on mobile then install it. I did the same but it didn't work.
    I still see android 10.
  18. Aaron2017
    KitKat Feb 10, 2021
    And you are sure it was the open beta 2 file?
  19. giorgraz
    giorgraz , Feb 10, 2021 :
    I have a 7pro with oxygen 10 version.
    I tried to install oxygen 11 beta 2 full rom via local update.
    On robot phone brick and restart only after full wipe and reback automatically to oxygen 10.
    Can someone help me ?
  20. Jadhav27
    Yes I reconfirmed it and it's the same beta 2.
