173
[SURVEY INSIDE] OxygenOS 11 Open Beta 2 for the OnePlus 7T and OnePlus 7T Pro
  1. Zheckan
    Froyo Feb 5, 2021
    Zheckan , via OnePlus 7T Pro , Feb 5, 2021 :
    Yes, I saw, but it was so convenient right in the camera app
  2. us4ak
    Froyo Feb 5, 2021
  3. Aaron2017
    Lollipop Feb 5, 2021
    Aaron2017 , Feb 5, 2021 :
    Did you disable optimised charging?
  4. Zheckan
    Froyo Feb 5, 2021
    AOD is available on OP7 pro & OP7t pro. Non pro series will available in next update
    tryfe likes this.
  5. johnsema
    Froyo Feb 5, 2021
    F1594487628271 likes this.
  6. SachinSoms
    Cupcake Feb 5, 2021
    Chris507 and MattHayesRVA like this.
  7. ghostofcain
    Marshmallow Feb 5, 2021
    ghostofcain , Feb 5, 2021 :
    A feature request in the correct place?
  8. OuterSpace
    Froyo Feb 5, 2021
  9. Shashank_Kumar
    Cupcake Feb 5, 2021
    Shashank_Kumar , via OnePlus 7T , Feb 5, 2021 :
    OP7T doesn't have Laboratory section in beta2.. It was there in beta1 ... Will Op7T get AOD in next beta version ???
    nswarnendu, Lemillion and tryfe like this.
  10. sameeh
    Gingerbread Feb 5, 2021
    sameeh , via OnePlus 7T , Feb 5, 2021 :
    May be
    Shashank_Kumar likes this.
  11. Aaron2017
    Did you try wiping the phone cache?it has helped others with their slow charging in OB1.
  12. OuterSpace
    Froyo Feb 5, 2021
    OuterSpace , via OnePlus 7T , Feb 5, 2021 :
    No but the beta wiped my data when I flashed it so I don't think that's the problem, I'll try it though
  13. sameeh
    Check it out after couple cycles,it needs time to work properly
    ghostofcain likes this.
  14. Vaibhav_sinha
    Honeycomb Feb 5, 2021
  15. Deessandhu
    Cupcake Feb 5, 2021
  16. tryfe
    Froyo Feb 5, 2021
    bobaoapae likes this.
  17. tryfe
    Froyo Feb 5, 2021
    tryfe , via OnePlus 7T , Feb 5, 2021 :
    Thought it was just me..
    Dipto79 likes this.
  18. AmitRao23
    G.Madhusudhan likes this.
  19. sameeh
    Psychosis69 likes this.
  20. JiyaDeenRashi
    Donut Feb 5, 2021
