60
[SURVEY INSIDE] OxygenOS 11 Open Beta 6 for OnePlus 8T
  1. P1625922675332
    Cupcake Jul 20, 2021
    P1625922675332 , via OnePlus 8T , Jul 20, 2021 :
    What will come beta update on one pluse 8T ?? And also some apps not available full screen Playing games is not fun on my OnePlus8T device the while playing games the display doesn't come on Full screen it only till front camera level have also shared the screen shots also not able to add any application on Full screen mode.................
    northbay5566 likes this.
  2. Wishnu_Mohan
  3. Jeff Alamo
    Gingerbread Jul 20, 2021
  4. M1524120700000
    M1524120700000 , via OnePlus 8T , Jul 20, 2021 :
    Sometime the device getting restarts automatically while an incoming call rings completely without answering. Then the device restart and device timing changes to random past date and time.
  5. northbay5566
    Jelly Bean Jul 20, 2021
    northbay5566 , via OnePlus 8T T-Mobile , Jul 20, 2021 :
    Give feedback in the section for the 8T 👍
  6. osmingab85
    Cupcake Jul 21, 2021
  7. Pratyush_adhikari
    Eclair Jul 21, 2021
    R1619568702222 likes this.
  8. Jeff Alamo
    Gingerbread Jul 21, 2021
    osmingab85 likes this.
  9. osmingab85
    Cupcake Jul 22, 2021
    Jeff Alamo and Antonygeorge99 like this.
  10. sathishask95
    Donut Jul 23, 2021
  11. Jeff Alamo
    Gingerbread Jul 23, 2021
  12. Vishal_Oneplus8t
    Froyo Jul 24, 2021
  13. Shidapu , via OnePlus 8T Lunar Silver , Jul 24, 2021 :
    Beta 7 out, no mention of fixed for Wifi no connection issue. So a big shout out to the developers, skip Android 11 beta and go for Android 12 straight away, hopefully the collaboration with Oppo devs can fix the wifi issue at hand.
  14. Louisbaecke510
    Ice Cream Sandwich Jul 24, 2021
  15. Louisbaecke510
  16. WantedHopes
    Eclair Jul 24, 2021
  17. hipy_10
    Donut Jul 24, 2021
    hipy_10 , Jul 24, 2021 :
    [QUOTE = "Shidapu, publicación: 23487180, miembro: 4502897"] Salida Beta 7, sin mención de arreglado para Wifi sin problema de conexión Así que un gran agradecimiento a los desarrolladores, omita Android 11 beta y opte por Android 12 de inmediato, con suerte la colaboración con los desarrolladores de Oppo puede solucionar el problema de wifi en cuestión. [/ QUOTE]
    Hi, would you be so kind as to tell me if you notice that turning off the phone takes a long time to turn off? I come from a oneplus 6T and it takes a second or two to turn off, and the 8t takes like 5 or 6 seconds, would you do me a favor to check it and tell me something ?, thanks in advance
  18. Bernest44
    Honeycomb Jul 24, 2021
    Bernest44 , via OnePlus 8T , Jul 24, 2021 :
    Beta 7 is AWESOME!! Battery is off the charts! Best I've seen. Charged it asap after the update to 85%.....and it's still holding to 63% with regular usage. Charged it this morning. Text....phone calls....and have even taken some pics and used Spotify. I'll drain to 20% and have another go at 85% and boost the usage to see if it really is this good
    manjuhyr59 likes this.
  19. manjuhyr59
    Eclair Jul 25, 2021
    manjuhyr59 , via OnePlus 8T , Jul 25, 2021 :
    I have installed the beta 7 and there are no unusual bugs. Battery performance seems to be improved. For me overnight ideal battery drain use to be generally 7 to 8 %. But last night it's just 2 % drain.
    Bernest44 likes this.
  20. Bernest44
    Honeycomb Jul 25, 2021
    Bernest44 , via OnePlus 8T , Jul 25, 2021 :
    Exactly!!!! Same here....mine was 3%.....was around 8%.
