83
[SURVEY INSIDE] OxygenOS Open Beta 13 for the OnePlus 7 Pro and 7
  1. Chakri._.Royal
    Cupcake May 8, 2020
    Chakri._.Royal , via OnePlus 7 Pro , May 8, 2020 :
    have you liked the new notifications icons n fonts..???
  2. Chakri._.Royal
    Cupcake May 8, 2020
    even i am getting the same thing for Google play music whenever i turn on my data or wifi..
  3. Swejuggalo
    Community Bug Hunter May 8, 2020
    Swejuggalo , via OnePlus 7 Pro , May 8, 2020 :
    Since I don't use play music I simply just deactivated it. It's probably some kind of "phone home", sync check.
  4. Chakri._.Royal
    Cupcake May 8, 2020
    i was so irritated with that stuff so i simply disabled play music 😅😅
    Swejuggalo likes this.
  5. Demon_hunter
    Honeycomb May 8, 2020
    Demon_hunter , via OnePlus 7 Pro , May 8, 2020 :
    It is not a simple hotfix,it was a very weird bug which occured in very less no of phones without any known common characteristics.
  6. sam311
    Ice Cream Sandwich May 8, 2020
    sam311 , via OnePlus 7 Pro , May 8, 2020 :
    okay I didn't know that
  7. derpull3rb0y
    Cupcake May 8, 2020
  8. suggestions
    Donut May 8, 2020
    suggestions , May 8, 2020 :
    i have hard reset my phone because no contact was showing,no call log generating and it was also affected whatsapp and other apps. Now after hard reset it is working well but also have some issue
    1. My bluetooth headphone (jbl 750btnc ) is not connecting automatically after i turned on bluetooth, now i connect it by going into the bluetooth setting and tapping the headphone name.
    2. Signal of primary Sim is getting weaker during uses of data instead of secondary sim
    3. April patch instead of May.
    4. Phone is getting hotter quickly during uses of high graphics games like pubg asphalt 9 etc.
  9. Batman360
    OnePlus Accessory Tester May 8, 2020
  10. A1582791282194
    Cupcake May 8, 2020
    A1582791282194 , May 8, 2020 :
    it shows like heads up watch carefully
  11. medodedo
    Cupcake May 8, 2020
  12. dantusris
    Gingerbread May 8, 2020
  13. AndiTheBassman , via OnePlus 8 Pro , May 8, 2020 :
    It seems they are working on it but it won't be rolled out until later this year. Maybe with Open Beta 18 or maybe never, who knows. From what I've read they want to make sure it has no significant impact on battery
  14. E1588257045378
    Cupcake May 8, 2020
    E1588257045378 , May 8, 2020 :
    Bonjour à tous les utilisateurs one plus !
    J'aimerais savoir quelle est la différence entre full update et incrémental update mise à part la taille du fichier?
    Je ne suis pas rooté j'ai une version stable d'oxygène os la dernière 10.0.5.GM21BA
    Si je fais la mise à jour beta la toute dernière est-ce que je dois sauvegarder quoi que ce soit de mon oneplus 7 pro avant la mise à jour?
    Merci pour vos retours...
  15. genialsandeep
  16. Swejuggalo
    I upgrade with no issues. But I did that on beta 12 too though.
    I got an issue though. But only once and I'm not sure if I can replicate. Mentioned higher up
    Batman360 likes this.
  17. Swejuggalo
  18. hpawank
    Cupcake May 8, 2020
    hpawank , May 8, 2020 :
    Hello OnePlus community !
    I'm facing issue that is all my contacts with same name are showing 2 to 3 times Any suggestions on how to fix this?
