83
[SURVEY INSIDE] OxygenOS Open Beta 13 for the OnePlus 7 Pro and 7
  1. Batman360
    OnePlus Accessory Tester May 8, 2020
    Batman360 , May 8, 2020 :
    Updated just now. Do you have some launcher issues? Like when you go to recent app and swipe right or left to select the app you want...is the right left scrolling smooth or does it lag? Coz mine is lagging since beta 12 recent app scrolling isn't smooth.
    My launcher version is 4.2.2
  2. Swejuggalo
    Lollipop May 8, 2020
    Swejuggalo , via OnePlus 7 Pro , May 8, 2020 :
    Everything seems to work great. Laucher 4.4.3
  3. Batman360
    This version is not installing on my 7pro idky
  4. Swejuggalo
    I'm on beta at Play store.
    Some downloaded and installed it via apkmirror. But had to uninstall launcher updates first
    Batman360 likes this.
  5. E1588257045378
    Cupcake May 8, 2020
    E1588257045378 , May 8, 2020 :
    Hello to all one plus users!
    I would like to know what is the difference between full update and incremental update apart from the file size?
    I am not rooted I have a stable version of oxygen os the latest 10.0.5.GM21BA
    If I do the latest beta update do I need to back up anything from my oneplus 7 pro before the update?
    Thank you for your feedback ...
  6. ShaunakSri
    Froyo May 8, 2020
    ShaunakSri , via OnePlus 7 , May 8, 2020 :
    I see they haven't mentioned that Gyroscope issue got fixed. It been 7 to 8 months me and many other people are crying to get it resolved, but seems like OnePlus don't bother to resolve the issue.
  7. Swejuggalo
    As long as an full update is newer than the installed version it does not matter what version you are on (with very few exeptions).
    An incremental needs a specific software version to be able to use it.
    Always backup if you don't want to risk loosing something important
    E1588257045378 likes this.
  8. Jay2020
    Ice Cream Sandwich May 8, 2020
  9. Jay2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , May 8, 2020 :
    Incremental vs fill Update:
    https://www.xanh.co.uk/full-vs-incremental-ota/
  10. R_d_M
    Gingerbread May 8, 2020
    Jay2020 likes this.
  11. Jay2020
  12. Batman360
    Lol yeah did the same this time 😂😂 Also started taking the backups 😂
    Jay2020 likes this.
  13. dcbarrett
    Cupcake May 8, 2020
    dcbarrett , May 8, 2020 :
    Same issue here. Noticed a significant drop in mobile signal.
    smitmakani and derpull3rb0y like this.
  14. medodedo
    Cupcake May 8, 2020
    medodedo , via OnePlus 7 Pro , May 8, 2020 :
    Override force-dark is not available in developer option after i installed OB 13 and no dark theme fo most applications like google and many others
  15. Jay2020
  16. Swejuggalo
    It has been removed some betas back. A new dark mode that is more useful will come to betas instead. Already in 8.
    All apps are dark just like before beta 13 for me
  17. smitmakani
    Froyo May 8, 2020
    smitmakani , May 8, 2020 :
    same here...
    my sim 2 has lost the volte lte connection.
    m only getting Edge / 2g network in sim 2 airtel.
    checked all the setting and in same area other are having 4g full network.
    already reported. just to share here.
    updated from OB12 to OB13. incremental and cleared cache.
