83
[SURVEY INSIDE] OxygenOS Open Beta 13 for the OnePlus 7 Pro and 7
  1. smitmakani
    Froyo May 8, 2020
    smitmakani , May 8, 2020 :
    i am on OB13,
    can i reflash OB13 full zip again on same version ?
    any steps to process will help.
    i dont want to downgrade.
    medodedo likes this.
  2. ShaswataBhowmick
    Eclair May 8, 2020
  3. Jay2020
    Ice Cream Sandwich May 8, 2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , May 8, 2020 :
    REF:
    smitmakani
    i am on OB13,
    REPLY:
    Yes, I have done it many times with the prior updates, probably still best to disable lock PIN/Passcode before doing. What's the reason you want to reflash?
    Yesterday I updated with the incremental Beta 13, since you had to go and bring it up LOL: I just now updated Beta 13 again. This time with Open Beta 13 Full Update. and here I am. All is well. [e]1f601[/e][e]1f601[/e][e]1f601[/e][e]1f44d[/e]
    Be sure to take your courage pills before doing this again. 😬
    smitmakani likes this.
  4. G_Sourav_Chakraborty_Xgt
    Gingerbread May 8, 2020
    G_Sourav_Chakraborty_Xgt , via OnePlus 7 , May 8, 2020 :
    I think battery problem issues not solved in 10.3.3 i know that and may be come bugs.
  5. W1568298283005
    Cupcake May 8, 2020
    W1568298283005 , via OnePlus 7 , May 8, 2020 :
    I'm not considering this as a MAJOR issue, but I've noticed FPS drops in low-light when using Snapchat or Instagram, which wasn't the case with previous version
  6. Jay2020
    FYI
    If you have done numerous updates over the past few months (especially Full Updates) you might want to delete the zip files in your Archives Folder. Over time theses files can eat up a lot of your phone's available storage.
  7. Manubown
    Cupcake May 8, 2020
  8. DMaarten
    Honeycomb May 8, 2020
  9. jagdish servi
  10. Swejuggalo
    Lollipop May 8, 2020
    Bharath1106 likes this.
  11. aVider
    Froyo May 8, 2020
    aVider , via OnePlus 7 Pro , May 8, 2020 :
    You probably have scheduled power off enabled.
    settings -> utilities -> schedule power off/on
  12. Swejuggalo likes this.
  13. Jay2020
    REF:
    Bharath1106
    what's this folks ... am facing it in midnight around 2 am for past two days after move on to beta 13 ....is this a problem or any bug or a default settings ... pls answer it OnePlus
    REPLY:
    Looks like you have your power off scheduler set.
    Go to settings/search for schedule/ click on Schedule Power Off/on.
    Rebooting your phone once a day is actually good for having your phone refreshed everyday. Mine reboots everyday at 4:45 a.m.
  14. G_Sourav_Chakraborty_Xgt
    When i play Pubg amd scope, screen is flicking, and every were pubg movements switch and others switches are visible in home screen, and extremely battery draining and heating. Please oneplus main topic is battery please fix this and gaming experience to bad. 10.3.2 version. Please fix this
    Ravitejanayudu likes this.
  15. Jay2020
    I don't think it's Open Beta 13. PUBG has been having some issues before OB13.
  16. Abhi goswamy
    Donut May 8, 2020
  17. Gustavo Aspauzo
    Eclair May 9, 2020
  18. L1537479603698
    Eclair May 9, 2020
    L1537479603698 , May 9, 2020 :
    Good after update do or PDC and return OEM scheme. Why is it not enabled? And cado or Wi-Fi 6 (axe) this is more important. AOD no matter it doesn't do it any differently
