83
[SURVEY INSIDE] OxygenOS Open Beta 13 for the OnePlus 7 Pro and 7
  1. RainGater
    Gingerbread May 10, 2020
  2. bipuwam
    Froyo May 10, 2020
  3. SaiKrishna.N
    Donut May 10, 2020
    RandyManLB likes this.
  4. Jay2020
    Ice Cream Sandwich May 10, 2020
    resurrectedserene likes this.
  5. rocksolidnaren
    Eclair May 10, 2020
  6. udayJR
    Froyo May 10, 2020
  7. Swejuggalo
    Lollipop May 10, 2020
    Swejuggalo , via OnePlus 7 Pro , May 10, 2020 :
    Launcher has a beta of it's own. I'm on beta on both launcher and OS.
    Are you sure the latest version you are looking after really is stable?
    Josue Prens likes this.
  8. DhruvX
    Eclair May 10, 2020
    DhruvX , May 10, 2020 :
    i am facing the same problem in settings
  9. Swejuggalo
    You probably have misunderstood what beta is. Here beta stays beta a big part of the device lifetime. If you start using beta you need to change to stable manually if you want stable.
    naikjeevan likes this.
  10. rocksolidnaren
    Eclair May 10, 2020
    rocksolidnaren , via OnePlus 7 , May 10, 2020 :
    that means all these beta features will not be added to stable version any time in future ????
  11. Swejuggalo
    Beta features are in beta until they deside they are ready for stable. No normal user knows when
  12. rocksolidnaren
    Eclair May 10, 2020
  13. mamorim90
    Cupcake May 10, 2020
    mamorim90 , May 10, 2020 :
    beta 13 is having cell isinganl issues with. 4G/LTE when compared to beta 11.
    anyone else notice this?
    maxsinghania and Dendedanamekian like this.
  14. Gertjan@
    Honeycomb May 10, 2020
    Gertjan@ , via OnePlus 7 Pro , May 10, 2020 :
    Question, does the Oneplus 7 T Pro McLaren also participate in the beta program, or does it also get the regular stable and beta updates as the regular Oneplus 7 T Pro.
  15. Akshay.Pathak
    Akshay.Pathak , via OnePlus 7 , May 10, 2020 :
    Just roll back to stable version oxygen os 10.3.2. you have to do a factory reset and have to flash the stable update zip.
  16. Swejuggalo
    It can use the same one as the rest of the 7t series as long as it is the standard 4g version.
  17. JmcRepair33
    JmcRepair33 , via OnePlus 7 Pro , May 10, 2020 :
    read instructions and you will see you need to manually download it. that's it simple.
  18. Gertjan@
    are there also 5g variants of it?
  19. Swejuggalo
