83
[SURVEY INSIDE] OxygenOS Open Beta 13 for the OnePlus 7 Pro and 7
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert May 15, 2020
    Swejuggalo , via OnePlus 7 Pro , May 15, 2020 :
    Some installed 4.4.4 beta by uninstalling laucher updates first.
    I simply got it via play store as beta tester
  2. Swejuggalo
    Deactivated User likes this.
  3. rikens2002
    Cupcake May 15, 2020
    rikens2002 , via OnePlus 7 Pro , May 15, 2020 :
    Hi please explain to me why on the official OnePlus page for downloading software update, it is showing downloads for March and no one at OnePlus have noticed.
  4. Saurabh_Tandon
    Eclair May 15, 2020
    Saurabh_Tandon , via OnePlus 7 Pro , May 15, 2020 :
    I once downloaded the apk update for one plus launcher. Does this mean that I won't get any further update from the play Store? Or would I, henceforth, have to update via the apk updates for the one plus launcher?
  5. Swejuggalo
    Oneplus homepage updates pretty late. What file do you want?
  6. Swejuggalo
    Only that you will not receive updates until reciving a update newer than that.
    Personally I would stay on normal relese or join beta for launcher (using beta myself)
  7. reZa7
    Eclair May 15, 2020
    reZa7 , via OnePlus 7 , May 15, 2020 :
    My launcher version is 4.4.2 and the higher version will not be updated, and when I want to install the new version, it will not be possible of course I have not received an update in Google Play
  8. Swejuggalo
    If you have for example downloaded 4.4.4 manually via apk mirror or something you may need to uninstall updates of the current one to update manually. Is that what you want to do?
    I still think it's best to use the version play store gives you either via stable or by joining beta of the app.
    Then you would not need this manual updating and stuff
    reZa7 likes this.
  9. rockinsnake
    Froyo May 15, 2020
    rockinsnake , via OnePlus 7 Pro , May 15, 2020 :
    I downgraded with previous downgrade package from beta 5 days and then installed the new beta built.... working lika charm!
  10. reZa7
    Eclair May 15, 2020
    Thank you
  11. Last edited by a moderator: May 16, 2020
  12. Salman Lodhi
    Froyo May 15, 2020
    Salman Lodhi , via OnePlus 7 , May 15, 2020 :
    gestures are not working sometimes... double tap wake up, flash light all these gestures are suddenly not working sometimes after this update....
  13. Nonochiken47
    Gingerbread May 15, 2020
    Nonochiken47 , via OnePlus 7 Pro , May 15, 2020 :
    It restarts just before you wake up or it's an hour randomly chooses. It's just to know if the chosen time has an impact on the optimization of the phone
  14. Y1577278738955
  15. Last edited by a moderator: May 16, 2020
  16. Last edited by a moderator: May 16, 2020
  17. Malachi_4pda
    Cupcake May 16, 2020
    Malachi_4pda , via OnePlus 7 Pro , May 16, 2020 :
    When blurry and low resolution UI elements, icons and buttons will be fixed? I have this issue since beta 11. Facebook, Instagram, Messenger, YouTube, Spotify and many other apps look horrible inside. Did anyone notice that?
