83
[SURVEY INSIDE] OxygenOS Open Beta 13 for the OnePlus 7 Pro and 7
  1. Arindams82
    Cupcake May 17, 2020
    Arindams82 , via OnePlus 7 , May 17, 2020 :
    Unfortunately ! for me it does not work. This issue cropped up in OB13 , earlier I never faced this problem in other beta's. Am wondering whether to wait for the next beta or downgraded to OB11 :(
  2. OkPro
    Donut May 17, 2020
  3. reZa7
    Eclair May 17, 2020
  4. reZa7
    Eclair May 17, 2020
    reZa7 , via OnePlus 7 , May 17, 2020 :
    I have the same problem
  5. Q1561086484453
    reZa7 likes this.
  6. DMaarten
    Honeycomb May 17, 2020
  7. NaveenRaju_VC
    Cupcake May 18, 2020
    NaveenRaju_VC , May 18, 2020 :
    Hi Jay, Thanks for the info. But what I meant is without external app, our built-in camera app should work fine
    Deactivated User likes this.
  8. Last edited by a moderator: May 18, 2020
  9. Piyush Moharana
    Ash_Patil likes this.
  10. wolf4477
    Froyo May 18, 2020
    wolf4477 , via OnePlus 7 , May 18, 2020 :
    I replied that, but effectively it didn't work, error appears randomly, I sent my log to oneplus when I was on op12 and seems they still don't resolve it, is annoying for me so I got back to stable version, and it run flawlessly, maybe when Android 11 appears I'll be back 😎
  11. Last edited by a moderator: May 18, 2020
  12. wolf4477
    Froyo May 18, 2020
    it is smooth and seem free of bugs, however you gonna loose some features like smart charging, chromatic mode on read mode, live caption, call recording even though never appears to me, boost download speed using WiFi and data neither is here, but otherwise, you have a great battery life. both of them has pros and cons.
  13. wolf4477
    Froyo May 18, 2020
    yes I had to go to Android 9, and then appears upgrade notification till oxygen 10, I had the issue that upgrade wasn't immediately, but you always can use oxygen updater app, and if you are smart can roll back your backup using oneplus switch or another backup app (I wasn't that guy, I forgot do backup 🤦) but almost every app that I use had synchronized data so I didn't lose info.
  14. JESTERS
    JESTERS , May 18, 2020 :
    I have an OP7PRO I just bought from someone that is on Open Beta 13. How exactly do I move back to the official by full install? Is there a guide on how to do this? Restoring to factory settings still has the phone in Beta 13, is there another way to do a clean flash?
  15. Pa1KumarM
    Gingerbread May 18, 2020
    Pa1KumarM , via OnePlus 7 Mirror Red , May 18, 2020 :
    In Open Beta 1 Thread you will find Rollback file for OnePlus 7 Pro
  16. James 007
  17. Last edited by a moderator: May 18, 2020
    Batman360 likes this.
  18. Santiago Vivarés
    Santiago Vivarés , via OnePlus 7 , May 18, 2020 :
    I have same issue since OB12set logs 2 times asked me 3rd I was too lazy to do it again.
  19. Vyacheslav113
    Vyacheslav113 , via OnePlus 7 Pro , May 18, 2020 :
    Hi, I'm using ob13 on my OnePlus 7 pro and I have a problem. Speed of the Internet when i use wifi hotspot is much slower on other devices then on my phone. For example, speed on my phone is ~4 mb/s but on the other devices (pc on windows/ps4/another phone) is like 500 kb/s. I've tried it in 5 and 2.4 ghz modes, but it is always slow. Please help me
    P.s. In ob11 everything was okey
  20. bayy27
    Eclair May 18, 2020
