83
[SURVEY INSIDE] OxygenOS Open Beta 13 for the OnePlus 7 Pro and 7
  1. Pa1KumarM likes this.
  2. G_Kirk_Fontaine_MBlG , via OnePlus 7 Pro T-Mobile , May 18, 2020 :
    I know this the thread for beta version but have a question for anyone that can help
    I am on the "stable" version of Android 10 having major media issues with the music apps just stop playing after loading 1 minutes in
    any suggestions?
  3. Vyacheslav113
    Cupcake May 18, 2020
  4. SeaRefractor
    Gingerbread May 18, 2020
    SeaRefractor , May 18, 2020 :
    I'm so glad that OnePlus continues to work hard on refining OxygenOS based on Android 10. I'm also looking forward to the eventual Open Beta for OxygenOS based on Android 11. I'm sure we'll here something about this after the official unveiling of Android 11 on June 3rd (was originally planned for Google IO which was canceled). I remember OnePlus working swiftly to have OxygenOS beta's available swiftly for Android 10. Keep up the good work OP!
  5. WunderJack
    WunderJack , via OnePlus 7 Pro , May 18, 2020 :
    Have you disabled all the "Battery optimization" options for your music apps?
    G_Kirk_Fontaine_MBlG likes this.
  6. xReborn
    Donut May 18, 2020
    xReborn , May 18, 2020 :
    My phone no longer charges to 100% FULL. It stops perfectly on 80%.
    When I do turn off my phone I can charge it to 100%.
    I'm running the latest beta build OP7Pro_02_BETA_13.
    I made sure that the optimized battery charge option has been turned off. Even when I don't turn it on/off it doesn't matter my phone charges perfectly till 80%. I also tried a other charger but same results.
    So my question is, is my battery charging "Bugged" or am I missing something stupid...
    Cheers in advance!
  7. Jay2020
    Ice Cream Sandwich May 18, 2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , May 18, 2020 :
    Do you have any 3rd party battery managing apps in installed on your phone?
  8. xReborn
    Donut May 18, 2020
    Not at all
    I mean I can install it to see if it "overrules"
  9. Jay2020
  10. SeaRefractor
    Seems odd you have that feature, seems like an app. There are a number of battery monitoring apps out there. It's a myth that stopping at 80% saves the battery though, however there are a large number of apps out there that will do this. How about a widget applied to help see the battery in an exciting manner? Probably has that setting.
  11. Jay2020
    Look through these post for some trouble shooting ideas.
    https://forums.oneplus.com/threads/sudden-battery-percentage-drop.547327/
    https://forums.oneplus.com/threads/phone-stops-charging-after-a-while.458248/
  12. Jay2020
    Ice Cream Sandwich May 19, 2020
    SwapnilNandre likes this.
  13. dinbandhukumar
  14. Q1589746398240
    Cupcake May 19, 2020
  15. sushantkadam0001
    sushantkadam0001 , May 19, 2020 :
    Alphabet missing on contacts icon | Phone App/Call History
    Contact already saved, still alphabet is missing on icons, having this issue only in "Phone App/Call History Tab".
    When you change the tab to "contacts" then again go back to "Call History" the icon will appear.
    All alphabet goes missing when we close the"Phone App" and again open.
    I hope oneplus team will look into it.
    Thanks.
  16. Gourav__kumar
    Gourav__kumar , May 19, 2020 :
    camera not able to click clear pictures at night.vivo v11 pro has 12MP but image clarity is far good compaired to Oneplus 7.i think i wasted my hard earned money buying this phone..if possible please work into it through a possible OTA update
    NaveenRaju_VC likes this.
  17. xReborn
    Donut May 19, 2020
    Jay2020 likes this.
  18. Nonochiken47
    Froyo May 19, 2020
    Nonochiken47 , via OnePlus 7 Pro , May 19, 2020 :
    I have a little problem, it does not directly concern the Open beta 13 but rather the oneplus launcher. I was beta launcher tester on the play store and since this morning weirdly I am not anymore. Google play told me a new launcher update (4.4.5) I did and there I notice that I am no longer a beta tester. Does anyone also have this problem???
  19. jagdish servi
    Gingerbread May 19, 2020
  20. jagdish servi
    jagdish servi , via OnePlus 7 Mirror Gray , May 19, 2020 :
    I too had that I used a app called beta maniac to re-sign as a tester it worked
