83
[SURVEY INSIDE] OxygenOS Open Beta 13 for the OnePlus 7 Pro and 7
  1. Lucazh
    Froyo May 19, 2020
    Lucazh , via OnePlus 7 Pro , May 19, 2020 :
    I use Chrooma by default, by I need gboard only for Chinese.
    and it continue to switch to gboard even if chrooma is set to default
  2. Swejuggalo
    Lollipop May 19, 2020
    Swejuggalo , via OnePlus 7 Pro , May 19, 2020 :
    I replicated that once too. Have you reported this via the feedback tool?
  3. Lucazh
    Froyo May 19, 2020
    yes, since OB10, always same reply. send the log and "thank you we are working on"
  4. N1560630073573
    Cupcake May 19, 2020
  5. chetannd
    Eclair May 19, 2020
  6. Swejuggalo
    Yepp. For 7 series there is only one beta version.
    Running it now too
  7. Pa1KumarM
    Gingerbread May 19, 2020
  8. N1560630073573
    RandyManLB likes this.
  9. TheMysticalShaman
    Honeycomb May 19, 2020
    maxsinghania likes this.
  10. Pa1KumarM
  11. sunand777
  12. Swejuggalo
    You get a free md5 verification and don't need to move the file or do anything other than do a local upgrade with the help of Oxygen Updater. There is no official links so using an inofficial tool would not be a problem either [e]1f609[/e]
    sunand777 likes this.
  13. SHIVAM97MANGLA
    Eclair May 19, 2020
  14. R_d_M
  15. DMaarten
  16. Ashgeeky
  17. Pa1KumarM
  18. Swejuggalo
