83
[SURVEY INSIDE] OxygenOS Open Beta 13 for the OnePlus 7 Pro and 7
  1. UtkarshSharma44
    Eclair May 19, 2020
    UtkarshSharma44 , via OnePlus 7 Pro , May 19, 2020 :
    OnePlus is providing beta updates.....but they are not focusing on stable updates at all.....they forgot the oneplus 7 series.....i am using oneplus 7pro, my first oneplus device and this is not a good thing that they are just giving the monthly security patches and nothing new feature in stable update.....please provide us the stable update with may security patch and Better battery life with maximum bugs fixed....and add some new features that are already there in beta updates....!!
  2. Swejuggalo
    Lollipop May 19, 2020
    Swejuggalo , via OnePlus 7 Pro , May 19, 2020 :
    Beta: 1 update every 2 week
    Stable: 1 update every 1-2 months
    This is the normal rollout of updates after the initial "new device" period.
    RandyManLB, Jay2020 and DMaarten like this.
  3. reZa7
    Cupcake May 19, 2020
    RandyManLB likes this.
  4. Swejuggalo
    If you want to wait on OTA or not is the question 😋
  5. A1577712634230
    A1577712634230 , via OnePlus 7 Pro , May 19, 2020 :
    havent recieved 10.3.3 till date via stable updates.
  6. A1577712634230
    Whats ur android version?? havent revieved 10.3.3 yet via stable update.
  7. UtkarshSharma44
    Eclair May 19, 2020
    i am on 10.3.2.....i am asking for 10.3.3.....or whatever they name it....waiting for next stable update from last 1month and 20 days.....still no update
  8. B1572816038978
    B1572816038978 , via OnePlus 7 Pro , May 19, 2020 :
    so after changing the clock style ( Beta 14 ) now the red first digit from default and digital 1 is gone only showing all grey in AOD. Tried restarting device same issue occurs. Can anyone else confirm this bug?
  9. Swejuggalo
    What exact clock type do you use now?
  10. Swejuggalo
    Replicated. Will see if I can find a way to recover it
  11. Jay2020
    Ice Cream Sandwich May 19, 2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , May 19, 2020 :
    not sure if there is a correct way. As an experiment before installing I cleared Cache from Recovery, disabled passcode, then with Oxygen Updater downloaded and installed the full Open Beta 14. All is working very well.
    reZa7 likes this.
  12. Swejuggalo
    Lollipop May 20, 2020
    Swejuggalo , via OnePlus 7 Pro , May 20, 2020 :
    The bug affects default and digital 1. All analog remains red
  13. B1572816038978
    Cupcake May 20, 2020
    B1572816038978 , via OnePlus 7 Pro , May 20, 2020 :
    First I went through all of styles to see how they look but after trying to revert to default that's it no more red first digit. On analog versions it does show the hour line in red so I guess only for Default and Digital 1. I'm using the default one atm but I will select analog version until next update hoping they will fix this bug as the AOD default clock with red digit is the best in my opinion.
    Swejuggalo likes this.
  14. Swejuggalo
    I got them back... First I force stopped the ambiant themes and wiped data and also force stopped Ambiant display and wiped data. Toggled forward and back now. So far still red number on old clocks
  15. 1207120
  16. Reji1996
    Donut May 20, 2020
  17. reZa7
    reZa7 , via OnePlus 7 , May 20, 2020 :
    Thanks
  18. David_VD
    Eclair May 20, 2020
    David_VD , via OnePlus 7 , May 20, 2020 :
    on this update I have been lucky if i reached 6 hours sot. usually i have 7-8 hours on the last update. even standby time has been quite bad with battery drain of around 7-15% overnight on the worst cases
  19. Jay2020
    Ice Cream Sandwich May 21, 2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , May 21, 2020 :
    RE:
    David_VD
    REPLY:
    I'm just not seeing bad battery performance with this update so far. I installed Open Beta 14 yesterday morning and last night overnight standby battery loss was only 1 to 2%. Charging only up to 92% and discharging down to 13% im still seeing at least 8 hours SOT. This is after only one recharge.
    My experience throughout each update: battery performance gets much better after a few recharging cycles. What I averaged with Open Beta 12 & 13 was 9 hours and 30 minutes. I'm sure I will start seeing that again after a few more recharge cycles. Open Beta 14 Screenshot below.
  20. TheAmlan
    Cupcake May 21, 2020
