83
[SURVEY INSIDE] OxygenOS Open Beta 13 for the OnePlus 7 Pro and 7
  1. Trouillot54
    Donut May 7, 2020
    Trouillot54 , via OnePlus 7 Pro , May 7, 2020 :
    salut oui sa ne trouve pas la mise a jour ses pas grave je vais l'attendre elle devrais pas tarder
    #61
  2. Trouillot54
    Donut May 7, 2020
    #62
  3. Jay2020
    Ice Cream Sandwich May 7, 2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , May 7, 2020 :
    RE:
    Trouillot54
    REPLY:
    Dans Oxygen Updater, appuyez sur les trois points dans le coin supérieur droit, puis sur Paramètres, assurez-vous que le mode avancé est activé et sélectionnez également la bêta ouverte incrémentielle.
    #63
  4. Okin107
    Eclair May 7, 2020
    Okin107 , May 7, 2020 :
    There are new status bar icons for wifi, signal etc. I kinda like them. wasn't mentioned anywhere.
    #64
  5. jagdish servi
    Gingerbread May 7, 2020
    jagdish servi , via OnePlus 7 Mirror Gray , May 7, 2020 :
    end of this month.
    #65
  6. MadyKarthi
    #66
  7. Rahul Jumani
    Cupcake May 7, 2020
    Rahul Jumani , via OnePlus 7 , May 7, 2020 :
    I was on beta 12, battery life was good. On beta 13, battery life is draining little fast.
    Also double tap to wake sometimes doesn't work just like beta 12.
    anyone with similar issues?
    #67
  8. jagdish servi
    #68
    Jay2020 likes this.
  9. suggestions
    Donut May 7, 2020
    #69
  10. maxsinghania
    Froyo May 7, 2020
    maxsinghania , via OnePlus 7 Pro , May 7, 2020 :
    1-try to clean cache from recovery or if u updated settings app manually.. uninstall that from app info!
    2- try to reset ur device...make sure u breakup ur data before doing this
    #70
  11. Jay2020
    Usually after an update, battery improves greatly after a few recharging cycles. Hang in there.
    #71
    Rahul Jumani likes this.
  12. maxsinghania
    Froyo May 7, 2020
    you will get incremental update....
    #72
  13. maxsinghania
    Froyo May 7, 2020
    I'm using this beta13 since 12 hours
    1- they have fix previous critical issue [e]270c[/e]️
    2- battery life is good I'm getting 1.5 hour more as compared to beta 11
    3- animation are faster now
    4- new recent app ui ,is awesome to switch between the apps
    5- on previous beta when we power on device ,we get black screen on lockscreen,we have to manually power on to
    access the lock.,it has fix in this beta
    6- icons look same as new OnePlus devices
    7-face unlocking has been fix in this beta
    [e]1f60a[/e][e]270c[/e]im ️ happy with this beta13
    @Manu J.
    #73
  14. O1588870818775
    Eclair May 7, 2020
    #74
    PravinkumarJ and DaRkNeSs9923 like this.
  15. Jay2020
    I had this same contract issue after first installing open beta 11. I tried many different things to get it to see my contacts, nothing worked. After a couple of days it was working again. It might have been the clearing Cache in Recovery and rebooting. Whatever you do, don't delete or change any of your contact files.
    #75
  16. E1545258953360 , via OnePlus 7 Pro , May 7, 2020 :
    article is from 2 weeks ago about the beta 12 update that got pulled but all the change log info is the same as the beta 13 that just got released. I thought new updates were supposed to improve on the previous update. I don't understand why customers put so much pressure on the company for updates to roll out so fast when it causes mistakes that in the end make the phones performance suffer and twice as many problems that need fixing in the next update. is there a way to find out what the stability issues were actually fixed between 12 and 13?
    #76
  17. U1578192405767
    Cupcake May 7, 2020
    #77
    Christiansotoa likes this.
  18. Bhavesh Bhoir
    Eclair May 7, 2020
    Bhavesh Bhoir , via OnePlus 7 Pro , May 7, 2020 :
    Did u wiped the cache from recovery?
    #78
  19. Rahul Jumani
    Cupcake May 7, 2020
    #79
  20. #80
