83
[SURVEY INSIDE] OxygenOS Open Beta 13 for the OnePlus 7 Pro and 7
  1. Skycake
    Cupcake May 7, 2020
    Skycake , via OnePlus 7 , May 7, 2020 :
    Hi man, could you please described what changed for the volume controls? How did they improve the low volume behaviour? is it really reduced compared with previous software?
  2. Swejuggalo
    Lollipop May 7, 2020
    Swejuggalo , via OnePlus 7 Pro , May 7, 2020 :
    Am I missing the point here? Beta 13 is just 12 with an hotfix. Nothing more (just like a normal hotfix)
  3. Jay2020
    Ice Cream Sandwich May 7, 2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , May 7, 2020 :
    Pretty much so, it seems to be the Beta 12 that most customers didn't get. So far Open Beta 13 seems worth the wait.
  4. Swejuggalo
    Exactly. Just fixing what 12 broke. Seems like some expected more from a hotfix
  5. jagdish servi
    Gingerbread May 7, 2020
  6. Jay2020
    Open Beta 13. I've been multitasking hard on my phone All morning and now my phone is asking me: Is That The Best You Got? It's kicking a** and taking names...
    Almost as bad a** as the OnePlus 8 Pro, almost. [e]1f601[/e][e]1f601[/e][e]1f601[/e]
    jagdish servi likes this.
  7. SHAAVEZ
    SHAAVEZ , via OnePlus 7 Pro Mirror Gray , May 7, 2020 :
    As soon as I updated to BETA 13, which I received now itself my launcher lagged a bit and something was downloading in the background for a while, I checked there was no update installed for the launcher. As you can see the network speed, the thing which a download symbol is of Google Play Music downloading something in background which I don't know why! and is there since BETA 10 🤷
    I'm afraid, are there any lags anyone found so far?
    Also are these bugs fixed?
    1. Black screen after rebooting
    2. Ghost updated of apps on Play Store, even though they are updated.
    3. Google Play Music downloading something in background glitch
    P.S. I was on BETA 12 without any issues and the BETA 13 was 153MB update for me approx.
  8. Jay2020
    No lagging here. What launcher are you using? have you thought about trying a 3rd party Launcher?
  9. SHAAVEZ
    Stock itself. Naeeh! I [e]2764[/e]️ the stock launcher [e]1f60a[/e]
  10. Swejuggalo
    Seen that happen for others too... Never got to know if it was solved and what they did though... Maybe clear data on play store and reboot?
  11. Jay2020
    I'm using Nova Launcher Prime: reliable, extremely customizable, very fast, light weight and 0 issues.
  12. Didit_Anshari
    Didit_Anshari , via OnePlus 7 Pro , May 7, 2020 :
    Clear data and dan cache of playstore and playservice then reboot should fix it. Happened to me as well
    Swejuggalo and Jay2020 like this.
  13. Nonochiken47
    Froyo May 7, 2020
    mholloway9856 likes this.
  14. Jay2020
  15. F1576846820814
    Cupcake May 7, 2020
    maazkazi1991 likes this.
  16. Siddharth_CH
    Cupcake May 7, 2020
    Siddharth_CH , via OnePlus 7 , May 7, 2020 :
    You can install stable versions but it will erase all your data. If you want to go back to stable, backup your stuff first
