100
[SURVEY INSIDE] OxygenOS Open Beta 14 for the OnePlus 7 Pro and 7
  1. Swejuggalo
    Lollipop May 21, 2020
    Swejuggalo , via OnePlus 7 Pro , May 21, 2020 :
    I haven't seen any official info about it. It works great here for me
    J1571092570140 likes this.
  2. A1559825473707
    Cupcake May 21, 2020
    A1559825473707 , via OnePlus 7 , May 21, 2020 :
    ok, thanks for suggestion
  3. Swejuggalo
    Stable update approx 1 update per 1-2 months.
    Beta 1 update every second week or up to 2 updates per month.
    You can always check when last update and count forward. That is the best info any of us have. Very rare with any other time frame info
  4. Swejuggalo
    I see 2 files... Sure you flashed the correct one? I was on beta 13 too and used the same full update to beta 14 with no problem
  5. Savio
    Donut May 21, 2020
    Savio , via OnePlus 7 , May 21, 2020 :
    No never iPhone. Better the new Pixel Going out in this year [e]1f609[/e]
  6. Akhilmunti
  7. x_jayreghe_x
    Gingerbread May 21, 2020
    x_jayreghe_x , via OnePlus 7 , May 21, 2020 :
    stable will be there before the end lf this month
    Akhilmunti likes this.
  8. SpinSupreme
    Eclair May 21, 2020
    SpinSupreme , via OnePlus 7 Pro , May 21, 2020 :
    I think some clarification of what beta builds are and how they are used to make software for some of you people who are trying to figure out why the stable builds aren't getting ota's... I'll try. the beta builds are tests to see if everything works, plain and simple. usually betas are behind the scenes and you never see or hear of them but all software goes thru a beta process before it is released. OnePlus is different as everyone knows and includes us in the process and I like everyone else am duly great full. I'm pretty sure that the reason the stable channel hasn't got an update in a while is because the last 2 beta updates (13 & 14) have had to be pulled because of serious problems found by beta testers. right now they are trying to fix whatever that was and will re-send the beta ota in hopes that version works better. when then beta channel receives an ota that works the way it's supposed to start to finish and the testers don't report any serious bugs then that build is rebranded as stable and released to the stable channel.. not until then. it could be the security patches causing the problem so I don't wanna hear about 'well they could just update the security patches' OnePlus will update the stable side when they have a stable build. I hope that helps.
    Swejuggalo likes this.
  9. cfrubio
    cfrubio , via OnePlus 7 Pro , May 21, 2020 :
    Yes, I tried to flash the latest one. I left the other one there so you guys can see which is the one currently running in my phone.
  10. Swejuggalo
    One of the files is beta 13...
    The other 10.3.1 it seems.
  11. cfrubio
    Swejuggalo
    Yes, the first one is Beta 13 (downloaded on 2020-05-07), the second one is supposed to be Beta 14 (that's the one I downloaded from the Beta 14 announcement on 2020-05-20). That's why it doesn't make any sense to get the error message about a lower version.
  12. Swejuggalo
    There is a possibility that they don't do beta x + beta z + beta y = stable or anything near that though.
    If parts of the beta code was planned to be cherry picked and introduced into stable and at a late stage discovered to be flawed, then we may get a delay.
    There is no delay yet though. While I don't know the exact date of rollout the actually announcement 2 month period is at the end of this month's. After that I guess we see more complaints 1 second after 2 months [e]1f609[/e]
    Sometimes I even see alternative ways of counting months and time with the complaints 😋
  13. Swejuggalo
    Well according to that picture you don't have beta 14...
    Beta 14 file name is this
    OnePlus7ProOxygen_13.W.35_OTA_035_all_2005122203_dfb6c8f59826ca0.zip
  14. E1560654196357
  15. udayJR
    Froyo May 21, 2020
    H@ppyj@ri likes this.
  16. Swejuggalo
    I don't know the exact date it started rolling out but the announcement was the last March. 2 months is the last this month. So it's not late yet. 1 update per 1-2 months. So basically anytime
  17. Adex0ne
    Ice Cream Sandwich May 21, 2020
  18. LarsDekkers
    LarsDekkers , May 21, 2020 :
    Is your automatic screen rotation on? Swipe down twice from the top and find auto-rotate, that should be on
  19. Jaweedtameem
    Eclair May 21, 2020
