96
[SURVEY INSIDE] OxygenOS Open Beta 14 for the OnePlus 7 Pro and 7
  1. vriesdejoop
    Ice Cream Sandwich May 22, 2020
    vriesdejoop , May 22, 2020 :
    How do you think that should be possible. If "pulled" people still recieve it officialy ???????
    Jay2020 likes this.
  2. genialsandeep
    Froyo May 22, 2020
    genialsandeep , via OnePlus 7 , May 22, 2020 :
    If anyone gets OTA, that means they had rectified the problems in OB14.
    That also means they are again pushing the new OTA... isn't it?
    Jay2020 likes this.
  3. Jay2020
  4. msbumm
    Cupcake May 22, 2020
  5. Jay2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , May 22, 2020 :
    [QUOTE
    Z1567989649345
    Does fingerprint auth still fail frequently from the ambient display?[/QUOTE
    REPLY:
    Having no issues with fingerprint unlock.
    Question. Does T-Mobile OnePlus have access to beta updates? If so how are you able to access any of the Beta's? Just curious. Thanks
  6. krishigandhi
  7. ASCHENTE_V
    Jelly Bean May 22, 2020
    ASCHENTE_V , May 22, 2020 :
    By carefully reading the original post by Abdul B. at the beginning of the thread.
  8. krishigandhi
  9. Jay2020
    REF:
    krishigandhi
    I want to become a part of beta tester on my OnePlus 7 how can I do so ?
    REPLY:
    Install and Open Oxygen Updater. Tap on the three dots in the upper right corner. Open Settings/ Select beta type/Turn on Advance mode. Put your seat belt on. You're good to go.
    krishigandhi likes this.
  10. chuckejeez , via OnePlus 7 Pro T-Mobile , May 22, 2020 :
    Fingerprint unlock works just fine from the lockscreen but never works from the ambient display.
    I'm not running the beta, just curious to know if the beta fixes that issue.
  11. MdArifHossan
    Donut May 22, 2020
  12. Jay2020
    chuckejeez
    REPLY:
    Works good for me OB14. From a screen off, I first have to double-tap, then slide padlock to the right, then 1st screenshot below, I touch fingerprint icon, phone unlocks./// I also use fingerprint unlock to (System app lock) unlock most apps on my phone, 1 second touch unlocks. No pocket booty calls for me
  13. Jay2020
    From back When running stable through multiple updates fingerprint unlock has always gotten better for me ( I always do Full updates, not incremental)
    What kind of fingerprint issue are you having?
  14. Jay2020
  15. chuckejeez , via OnePlus 7 Pro T-Mobile , May 22, 2020 :
    From screen off, double tap. Ambient Mode will show time, notification dots, and fingerprint.
    When I attempt to use fingerprint in Ambient Mode in anything but daylight conditions, it will fail to read my fingerprint saying that I moved it too quickly, even when it's been stationary the entire time.
  16. vmurali69
  17. Jay2020
    do you have a screenshot of your Ambiant Settings? I can try and see if I get the same issue outcome.
