100
[SURVEY INSIDE] OxygenOS Open Beta 14 for the OnePlus 7 Pro and 7
  1. Pa_One
    Eclair May 23, 2020
  2. Pa_One
    Eclair May 23, 2020
    krishigandhi likes this.
  3. cruzAD
    Gingerbread May 23, 2020
    cruzAD , via OnePlus 8 , May 23, 2020 :
    With this new OB 14 update when I make a restart, after restart the phone writes The Call Recording is banned in your phone bc. you have a wrong SIM in it what is belong to a wrong country where call recording is banned, bla.. bla.. bla
    I have Call Recording enabled via ADB and jOnePlus Tools, but I getting this warning message after each restart, but the call recording is works anyway.
  4. jagdish servi
    jagdish servi , via OnePlus 7 Mirror Gray , May 23, 2020 :
    what are your issues?? I was recently contacted by a oneplus developer for sending reports of my bugs.
  5. Swejuggalo
    Lollipop May 23, 2020
    Swejuggalo , via OnePlus 7 Pro , May 23, 2020 :
    Yeah... The longer run time the higher risk of strange issues like that. Trying to catch similar behavior while logging it on my phone
    cruzAD likes this.
  6. Swejuggalo
    After 38h run time touch over fingerprint reader was not responsive. Noticed that by V on 2 different keyboards was not possible to use. The fingernprint reader in itself worked though. Soon after that System UI started to go nuts and asked me to kill it or wait. I choose wait to see how it behaved. The system was unresponsive on and off every now and then during the time System UI acted crazy. I catched logs and did as much error reporting I could until I gave up and rebooted. Now I have logging on since 42 hours back trying to get back to a troublesome situation. Doing my best to trigger it again 😋
    Hopefully I get better logs this time.
    cruzAD and jagdish servi like this.
  7. akks
    KitKat May 23, 2020
    akks , May 23, 2020 :
    I'm yet to encounter one, then:(
  8. yashj_17
    Donut May 23, 2020
    kingslim likes this.
  9. arun1092
    arun1092 , via OnePlus 7 , May 23, 2020 :
    Whatsapp Voice notes invokes in ear detection randomly, which should be given more priority over new features. as its the most used social app these days - a request. I have looked over each beta but no mention of it. Atleast provide an option to turn off that sensor..
    MNMNASIF likes this.
  10. SougataMani
    Cupcake May 23, 2020
  11. genialsandeep
    Froyo May 23, 2020
    genialsandeep , via OnePlus 7 , May 23, 2020 :
    arun1092
    Whatsapp Voice notes invokes in ear detection randomly, which should be given more priority over new features. as its the most used social app these days - a request. I have looked over each beta but no mention of it. Atleast provide an option to turn off that sensor..​
    Did you try these..
    1. Dolby atmos sound setting from dynamic to music.
    2. Developer options>Quick settings developer tiles>sensors off enable
    Try one after another...one of them might works.
    arun1092 likes this.
  12. SougataMani
    SougataMani , via OnePlus 7 Pro , May 23, 2020 :
    yeah i also faced major issue the YouTube app and many more apps some words and some icons got hazy
  13. arun1092
    thank you...i tried seperate threads to avoid such comments in threads.. but no one replied... guess i should have posted here at first [e]1f44d[/e]🏻[e]1f60a[/e]
    genialsandeep likes this.
  14. Swejuggalo
    I don't have that problem. I have the screen in auto resolution mode. Both YouTube and Facebook is sharp to me
  15. Yashwanth1799
    Froyo May 23, 2020
  16. SougataMani
  17. Swejuggalo
    There is a function in whatsapp that makes it use the ear speaker mode... Just in case you want to listen in private.
    The problem is how the virtual proximity acts.
    Personally I would have prefered a manual override on the app so you are not forced to rely on the proximity.
    You can test the behavior on how the proximity acts with apps like this.
    The amount of unintended proximity reading is crazy. But I highly recommend trying it to get a good idea of how the proximity works.
    https://play.google.com/store/apps/details?id=com.argonremote.proximitysensorcounter
  18. Swejuggalo
  19. SougataMani
    qhd+ and 90hz i also reinstall apps which those i hava issue but not fixed at all . so i go back to stable version or open beta 13 ? if i step back to open beta 13 is my data wipe ?
  20. Swejuggalo
    My settings on beta 14.
    fahadleee and wawanredblack like this.
