100
[SURVEY INSIDE] OxygenOS Open Beta 14 for the OnePlus 7 Pro and 7
  1. Swejuggalo
    Lollipop May 23, 2020
    Swejuggalo , via OnePlus 7 Pro , May 23, 2020 :
    Go back is only possible with data loss (atleast on devices with locked bootloader). Since I don't have the problem check different settings combos first
  2. Jay2020
    Ice Cream Sandwich May 23, 2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , May 23, 2020 :
    Yeah, it loo like it doesn't have much endurance the more I use OB14. So far I haven't got locked out. lol. [e]1f601[/e][e]1f44d[/e]
  3. SougataMani
    Donut May 23, 2020
    SougataMani , via OnePlus 7 Pro , May 23, 2020 :
    same no change
    so am i wait for open beta 15 or switch back to 13 ?
  4. Swejuggalo
    Had some issues that I was about to verify on beta 13 too (also only around 2 days uptime)... But then beta 14 came so I started using that. So all issues is not new in beta 14. Perhaps slightly worse. May be Pro limited or only for some using certain stuff or so...
    Some of my beta 13 issues is being looked at and has been noted by the devs. For example... Battery charge icon could for example stick and still show that it was connected until dropping below 100% charge [e]1f609[/e] (but only at 2 days and beyond). So some issues at system level
  5. Swejuggalo
  6. SougataMani
    Donut May 23, 2020
    yeah switch back to same settings and same issue .
    so what is good to do wait for next update or switch back to op13 or switch back to stable version ?
  7. Swejuggalo
  8. Swejuggalo
    If that is your only problem I would wait
  9. SougataMani
    Donut May 23, 2020
  10. A1582791282194
    Cupcake May 23, 2020
    A1582791282194 , via OnePlus 7 , May 23, 2020 :
    almost for 2 months there is no update for oneplus 7 stable users really,its annoying oneplus team.eve there is no monthly security update.pls do concern for us its very bad and the company is just regreting the onepkus users.
  11. Swejuggalo
    Yepp almost 2 month. Nothing out of the ordinary really.
    As always... 1-2 months after last update. Any time during that time is perfectly normal.
    And bi-monthly security is the standard when it comes to Oneplus. It's officially announced but could use a better way to inform the users of it since so many does not know about it
    wolf4477 likes this.
  12. M1584330908118
  13. Swejuggalo
  14. M1584330908118
    M1584330908118 , May 23, 2020 :
    thanks for your information..🤝🤝
  15. ram97prasath
    ram97prasath , via OnePlus 7 , May 23, 2020 :
    even I am facing the same issue
  16. arockiaayyadurai
    Froyo May 23, 2020
    arockiaayyadurai , via OnePlus 7 , May 23, 2020 :
    Overall Nice. App locker settings, we are using the same password which we normally unlock the phone.. My suggestions, App locker needs separate password facility...
  17. Swejuggalo
    As in tap to wake does not work? Or lift to wake?
    Ambiant display issues seems more common on 7 than 7 Pro
  18. Jay2020
    Swejuggalo
    I was wonder, how could OnePlus take something ( OB-11) that was running so smoothly and top notch and mess it up so badly (OB-12, 13 & 14)?
    All that aside, it's still kicking A** and taking names... 😛😛😛
  19. Swejuggalo
    A guess... Integration of stuff added to 8 series into 7 series code. We have already seen the icons change and behind that probably much more changed than just the icons.
    Greater leaps than usual may end up giving you a few bruises here and there 😋
    Personally I feel it's more fun when a lot of things happen. Even if it may end up that I need to reboot more often for stability. Right now I kind of hope all hell breaks loose so I can send in some useful logs [e]1f609[/e]
  20. Vidvat@3
    Froyo May 23, 2020
