100
[SURVEY INSIDE] OxygenOS Open Beta 14 for the OnePlus 7 Pro and 7
  1. Iamsuniljinde
    Eclair May 23, 2020
  2. Jay2020
    Ice Cream Sandwich May 23, 2020
    Iamsuniljinde likes this.
  3. genialsandeep
    Froyo May 23, 2020
  4. ASCHENTE_V
    Jelly Bean May 23, 2020
    ASCHENTE_V , May 23, 2020 :
    How should we know that?
    DMaarten likes this.
  5. genialsandeep
    Froyo May 23, 2020
    genialsandeep , via OnePlus 7 , May 23, 2020 :
    By experience I guess.
    I migrated from stable to OB13 2days back.
    You guys are here in Beta for a long time.... didn't they pull back before?
  6. RandyManLB
    Froyo May 23, 2020
    RandyManLB , via OnePlus 7 , May 23, 2020 :
    Thank you! OB14 running fine on my OP7. Killer battery time. [e]1f44d[/e]
  7. ellisconor
    Cupcake May 23, 2020
    ellisconor , via OnePlus 7 Pro , May 23, 2020 :
    Whilst the clock styles are varied, I just wish we could change the red accents. Why isn't the clock accent colour linked to the themes accent colour? It just doesn't make sense...
  8. JanmeshJ
    Donut May 23, 2020
    JanmeshJ , via OnePlus 7 Pro , May 23, 2020 :
    Red accent is the OnePlus way.
    The red cable club and everything.
    Red defines OnePlus
    Artemus. likes this.
  9. Swejuggalo
    Lollipop May 23, 2020
    Swejuggalo , via OnePlus 7 Pro , May 23, 2020 :
    If it comes back with modifications it will most probably be beta 15. However the beta 4 on some 7t came back unmodified. Don't know if that applies to all 7t though...
  10. Jay2020
    Swejuggalo likes this.
  11. ellisconor
    Well then why give us the accent colour customisation options for the device theme? Might as well change that to red and remove the option...
    The OnePlus way is Never Settle, it sure feels to me that if I want that ambient display clock I have to settle for red. I get that it's an important part of branding, so sure... default to red but give us the option. Isn't the beauty of Oxygen OS that it is a near stock version of Android but with an amazing amount of customisation options?
  12. ASCHENTE_V
    If 1+ gives the way to customize everything, it would be Xiaomi.
    rohitvarma1986 likes this.
  13. CHA0SENG7NE
    Eclair May 23, 2020
  14. Swejuggalo
  15. ellisconor
    The ambient display is an extension of the UI essentially, it's not a big reach to ask that the accent colour of the ambient display should follow the system theme. I'm not asking for more customisation pushing the software into becoming something that would be found on Xiaomi devices, just for a very minor cosmetic option. Simple, yet helps extend the device accent colour to cover... well all the device. Isn't that not the point of setting a device wide accent colour?
  16. prabaltitanium27 , via OnePlus 7 Pro , May 23, 2020 :
    Hey brother, i just needed to ask one question. How do you take such screenshots? Showing the whole phone and the intended content too?
  17. ASCHENTE_V
    "Isn't the beauty of Oxygen OS that it is a near stock version of Android but with an amazing amount of customisation options?"
    These are your words... They don't correspond with your new post. My answer is NO. No endless fonts, no themes that will make your ui look like One Ui, Miui, ios... God save us from it.
  18. Jay2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , May 23, 2020 :
    CHA0SENG7NE
    If you have updated to beta 14 can you go back to version 13?​
    REPLY:
    You have to go all the way back to the beginning of the line ( to Android 9), then work your way back up to the front ( Android 11,12 then 13 ).
    ...Downgrade back to Android 9 then update to Android 10, then switch to beta and last work your updates up to open beta 13...
    Way too much fun.[e]1f44d[/e][e]1f601[/e][e]1f601[/e][e]1f601[/e]
    https://forums.oneplus.com/threads/...-for-the-oneplus-7-and-oneplus-7-pro.1099154/
  19. Jay2020
    prabaltitanium27 likes this.
  20. Jav P
    Honeycomb May 23, 2020
    Jav P , via OnePlus 7 , May 23, 2020 :
    Try Snapmod from the Play Store.
