100
[SURVEY INSIDE] OxygenOS Open Beta 14 for the OnePlus 7 Pro and 7
  1. nikha
    Donut May 20, 2020
    nikha , via OnePlus 7 Pro , May 20, 2020 :
    Are people in India getting the OTA update? if not which region is receiving ota update. I am in northern California, but don't see anything
    #81
  2. inoobx3
    Froyo May 20, 2020
    inoobx3 , via OnePlus 7 Pro , May 20, 2020 :
    hello yesterday i received the notification to update to open beta 14 however i did not download it yet.. today i have connected to a wifi and wanna try downloading it but the update someone have gone missing and system saying my software is updated ( currently on open beta 13 ) anyone can clarify or help me?
    #82
  3. Bhavesh Bhoir
    Eclair May 20, 2020
    #83
  4. genialsandeep
    Gingerbread May 20, 2020
    genialsandeep , via OnePlus 7 , May 20, 2020 :
    You lost your chance buddy...wait like everyone else
    #84
  5. laikexpert
    Honeycomb May 20, 2020
    laikexpert , May 20, 2020 :
    2.1 GB
    Full Global version)
    http://otafsg1.h2os.com/patch/amazo...35_OTA_035_all_2005122203_dfb6c8f59826ca0.zip
    How to update:
    • Save the ZIP package to the root of your OnePlus smartphone’s storage (i.e., not in a folder such as Downloads, for example).
    • Open Settings and head to System > System updates.
    • Tap the gear icon in the upper right corner.
    • Tap on Local upgrade.
    • You should see the ZIP file you downloaded. If you don’t, you need to move it to the root directory. Do so and repeat these steps if that’s the case.
    • Tap the ZIP file and allow Oxygen OS to install it.
    • You’ll get a notification that you need to reboot once it’s done installing, which you should do by hitting the button.
    • Your phone will reboot. Once it’s done, you’ll be on the latest version of Oxygen OS.
    • To check your current version, head to Settings > About phone and check your build number.
    P.S
    Luckily, it’s easy to update OnePlus smartphones with the latest version of Oxygen OS without needing to wait for the company to push the notification to you. It takes a little extra effort on your part, but if you’re the type of person who wants the latest updates immediately, you should know how to do it.
    #85
    HoloSpark96, subrotorion and inoobx3 like this.
  6. inoobx3
    Froyo May 20, 2020
    #86
  7. maverick2017
    Cupcake May 20, 2020
    maverick2017 , via OnePlus 7 Pro , May 20, 2020 :
    Good to see that there is actually something new in the Open Beta (apart from system bug fixes). Referring to the additional watch faces. However, will they actually make it to a final build released anytime soon? Don't remember what was the last feature introduced in a Beta, that went on to be included in the final version.
    #87
  8. Alcitron
    Donut May 20, 2020
    Alcitron , via OnePlus 7 Pro , May 20, 2020 :
    I just updated to the beta 14 version.
    i went to the call history, three dots on upper right corner but i am not able to see the call recording option you mentioned..
    #88
    _Salman_Sallu_ likes this.
  9. aakarshmodi
    Eclair May 20, 2020
    aakarshmodi , via OnePlus 7 , May 20, 2020 :
    make a new phone call and then u will see that option. feature not working for older call history
    #89
  10. Alcitron
    Donut May 20, 2020
    ooohhh ok my fault then, thank u very much for the info.
    #90
  11. genialsandeep
    They push the OTA updates to random people initially for testing.
    You are one of those lucky random people.
    But unfortunately you didn't update...That means you chose to wait for the bug free update...wait for few days you will get it.
    You should have clicked the download button when you saw the update notification.... you can pause it anytime.. even after 1kb download..but you should have clicked it.
    #91
  12. xSuzy
    xSuzy , May 20, 2020 :
    download fails after 398mb, anyone facing the same issue?
    #92
    Doombot23 likes this.
  13. inoobx3
    Froyo May 20, 2020
    ahh okay.. thanks for the info
    #93
  14. AndiTheBassman , via OnePlus 8 Pro , May 20, 2020 :
    I really like the new Clock Customisation Option and the Dark Mode Toggle. Hope they'll find their way into my 8 Pro soon.
    I'm wondering if the "one hand mode will ever find a comeback" I actually liked the idea and think it could be quite useful
    #94
  15. W1565118363577
    W1565118363577 , via OnePlus 7 , May 20, 2020 :
    Была проблема с блокировкой экрана. После блокировки телефон не реагирует на поднятие и на касание. После обновления на beta 14 стало ещё хуже. Раньше иногда срабатывал на поднятие, сейчас сразу после блокировки не возможно разбудить пока не нажмёшь кнопку вк/выкл. В настройках все включено. Очень не удобно . Help.
    #95
  16. G_Sjak_Philipsen_yrCq
    #96
  17. Enigmaxregrem
    #97
  18. donPepitoGrillo
    Ice Cream Sandwich May 20, 2020
    donPepitoGrillo , May 20, 2020 :
    If you can't wait for an update, then I think the problem is yours, not OnePlus
    #98
  19. 1207120
    #99
  20. x_jayreghe_x
    x_jayreghe_x , via OnePlus 7 , May 20, 2020 :
    click on the 3 dots of the contact , it'll appear there.
