100
[SURVEY INSIDE] OxygenOS Open Beta 14 for the OnePlus 7 Pro and 7
  1. jagdish servi
    Gingerbread May 27, 2020
    jagdish servi , via OnePlus 7 Mirror Gray , May 27, 2020 :
    did u receive the notification via oxygen os updater or system??
  2. Swejuggalo
    Lollipop May 27, 2020
    Swejuggalo , via OnePlus 7 Pro , May 27, 2020 :
    Let's take ob4 on 7t..they brought it back with the same Md5... No modification done,atleast on International. If someone gets their hands on a full file compare with the old one. No point in flashing the exact same file with just a different name...
    Also I have never seen any single update getting modified and re-released with the same version number. It usually not the way devs do
    justine.mathew likes this.
  3. laikexpert
    Honeycomb May 27, 2020
    Shalin235 and Swejuggalo like this.
  4. justine.mathew
    justine.mathew , via OnePlus 7 , May 27, 2020 :
    true
  5. pablofg1978
    Nougat Head Moderator May 27, 2020
  6. pablofg1978
    pablofg1978 , May 27, 2020 :
    If you dont explain the problem, nobody can tell you how to fix it
  7. udayJR
    Froyo May 27, 2020
    udayJR , via OnePlus 7 , May 27, 2020 :
    OnePlus 6 and 6T has received the latest update with the May security patch. Hopefully, our devices will get it by this week
  8. Sieniuss
    Cupcake May 27, 2020
  9. pablofg1978
    can you say what does the error says? What app are you trying to capture
  10. pablofg1978
    Are you using the beta?
  11. pablofg1978
    I merged your thread with the official beta thread, please use this thread for any beta related discussion. Instructions on how to report your issues are in the first post
  12. c3drik67
    c3drik67 , May 27, 2020 :
    Screenshot work on my op7pro with beta 14...
  13. c3drik67
    Test a wipe cache in recovery maybe solve your issue. I do that after an update.
