100
[SURVEY INSIDE] OxygenOS Open Beta 14 for the OnePlus 7 Pro and 7
  1. genialsandeep
    Froyo May 29, 2020
    genialsandeep , via OnePlus 7 , May 29, 2020 :
    Did you guys see this?
    We can add Amazon music widget in shelf.
    And it fits comfortably.
    Best thing is we can interact with Alexa from here..not only music we can ask any question...Its very useful.
    I don't know if it is available in stable version...I guess it does but I didn't notice back then.
  2. Jay2020
    Ice Cream Sandwich May 29, 2020
  3. Ashwin9417
    Eclair May 29, 2020
  4. Jay2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , May 29, 2020 :
    U1568742994042
    charging is very slow,..........pls can share how much time takes from 0 to 100.......pls share i m feeling slow charging speed
    REPLY:
    OB-14: Total charging from 0 to100% average time is about 75 to 80 minutes. Charging is very fast up to about 90-95%, then charging speed tapers down the last 15 minutes. . Battery SOT average 8 hours and 30 minutes. Works for me. Prior phones ( Samsungs) had averaged 3 hours charging time.
  5. Jay2020
    Ashwin9417
    when closing the apps from the recent apps the lag between the screen disappearing and the icon disappearing is kind of annoying.​
    No issues here OnePlus 7 Pro. Closing apps completely in Recent is very fast Which Open Beta are you on? I noticed you have icons at the bottom in your Recents, might be a Launcher issue. I am on Nova Launcher Prime and no lag issues in Recents.
  6. Ashwin9417
    Eclair May 29, 2020
  7. Ashwin9417
    Eclair May 29, 2020
  8. Jay2020
    Ashwin9417
    It only comes when you use the bar for gestures​
    You're using Gestures? I don't use Gestures, but I've seen some mentioned that Gestures has some bugs. Maybe testing app closings in Recents with Gestures turned off and see if it still lags. This will help see if the real culprit is possibly Gestures?
  9. nilanslg
    Donut May 29, 2020
    nilanslg , via OnePlus 7 Pro , May 29, 2020 :
    hey. i was on open beta 13. as 12 was skipped. now its ob 14. only 186 mb update it was.
  10. Swejuggalo
    Lollipop May 29, 2020
    Swejuggalo , via OnePlus 7 Pro , May 29, 2020 :
    Very strange if the incremental changed but not the full file.
  11. Ashwin9417
    Eclair May 29, 2020
    Ashwin9417 , via OnePlus 7 , May 29, 2020 :
    we are all beta testers and it's one of our job to find the bugs and report it.
    Jay2020 likes this.
  12. Jay2020
    Ashwin9417 likes this.
  13. U1568742994042
    Eclair May 29, 2020
    U1568742994042 , May 29, 2020 :
    thanks for reply......i dont know y it takes 100 min to 100% charge
  14. Nonochiken47
    Froyo May 29, 2020
    Nonochiken47 , via OnePlus 7 Pro , May 29, 2020 :
    U1568742994042
    It's probably due to the Optimized Charging. Try disable it and see the difference
    Jay2020 likes this.
  15. U1568742994042
    Eclair May 29, 2020
    u use with disabled optimization charging
  16. Nonochiken47
    Froyo May 29, 2020
    U1568742994042
    u use with disabled optimization charging​
    Yes, because I do not need it. I rarely charge my phone at night. in addition it charges faster without. Disable it and see the difference
    Jay2020 likes this.
  17. G_Dave_Breen_KBHB
    Cupcake May 29, 2020
  18. Scorpiosunset
    Cupcake May 30, 2020
    Scorpiosunset , via OnePlus 7 Pro , May 30, 2020 :
    The version they pulled, the battery life was terrible. Don't know about this version.....
  19. jayesh2222
  20. Swejuggalo
    Lollipop May 30, 2020
