100
[SURVEY INSIDE] OxygenOS Open Beta 14 for the OnePlus 7 Pro and 7
  1. harshalpohare5
    Froyo May 30, 2020
    harshalpohare5 , May 30, 2020 :
    Amoled Dark Black.
    Although, even you could help by answering my Query 🤷🏻‍♂️
    KathiravanJLR likes this.
  2. Jay2020
    Ice Cream Sandwich May 30, 2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , May 30, 2020 :
    Vickie gowda
    I'm on latest stable 10.3.3 ,but now I wanted to switch to beta channel so I downloaded open beta 14 from OnePlus download page n placed it inside internal storage .........now wen I'm trying to install d open beta 14 itz showing selected package is lower dan current version so wat shud i do now to get to beta channel?
    REPLY:
    see posting #1061 in this thread, much easier.
    quickly go to page 54 per screenshot below.
    ALSO NOTING THAT YOU HAVE ALREADY UPDATED TO 10.3.3, You may have to wait now until open beta 15 is available. if you follow instructions at posting#1061 it will notify you when OB15 becomes available. Your current Stable is newer then the current Beta. STOP updating Stable if you want to switch to open beta.
  3. KathiravanJLR
    Gingerbread May 30, 2020
  4. naikjeevan
    naikjeevan , via OnePlus 7 Pro , May 30, 2020 :
    How did you do that??
    The image you attached.. photoshop??
  5. Jay2020
    naikjeevan
    REPLY:
    Sorry, me speak no English. LOL, Just kidding. [e]1f601[/e] The app is called Snapmod. Here's the link:
    https://play.google.com/store/apps/details?id=cn.gavinliu.snapmod
    Careful: may cause heart attack, heartache, bend over backwards syndrome, drooling at the lip (right side), diaper rash, grinning ear to ear and way way too much fun disease. Enjoy. [e]1f601[/e][e]1f601[/e][e]1f601[/e]
    naikjeevan likes this.
  6. naikjeevan
    While scrolling settings there is colour shifting & also there is a delay in the movement of left side icons at low brightness..
    Also seen in play store if an app has black background.
    Tried cleaning cache still there.
    Is anyone else having this same issue?
  7. naikjeevan
    Jay2020 likes this.
  8. colossusr
    Froyo May 30, 2020
    colossusr , May 30, 2020 :
    It's working all the time on my OnePlus 7
  9. Jay2020
    naikjeevan
    REPLY:
    You haven't changed Smallest Width up or down in Developer Options have you? Adjusting this too high or too low can have the same effect. If you are on the OnePlus 7 Pro make sure it's still set at 411dp.
  10. O1588870818775
    Eclair May 31, 2020
    O1588870818775 , May 31, 2020 :
    When there is light, the double tap works fine, as soon as it gets dark, it stops working. Is there a problem in the sensor?
  11. Naytun
    Cupcake May 31, 2020
  12. naikjeevan
    Gingerbread May 31, 2020
    naikjeevan , via OnePlus 7 Pro , May 31, 2020 :
    I don't know how but that value was 470dp, I have changed it to 411dp.. But the issue is still there.
  13. Jay2020
    Ice Cream Sandwich May 31, 2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , May 31, 2020 :
    Try rebooting after changing. That is my OnePlus 7 Pro default setting: 411dp. It may not be the issue on your phone, but when this number it too high or too low the screen problems are like what you're describing.
  14. naikjeevan
    I did as you said.. changed the value to 411dp & restarted, issue is still there. The value was 470dp b'coz I keep the font size & display size both small, have been this setting from the day I got the phone.
    Issue am having is like the white text, the grey lines & black background are moving at different speed, which is causing the color shift. I tried screen record it but it's not visible in the video.
    It's minor & only visible at lowest brightness, but it sure is visible & irritating while using at night.
  15. akks
    KitKat May 31, 2020
  16. Artemus.
    Nougat May 31, 2020
  17. Jay2020
    Worst-case scenario you may have to Factory Reset your phone. If you still have the problem after that, the issue is likely hardware related.
  18. Jay2020
    naikjeevan
    REPLY:
    Your dp might have changed in relation to the font size. which makes sense, they both effect dpi. If there is a setting that is incorrect somewhere on your phone a factory reset should correct it. No drop incidents or water incidents recently?
  19. BuxtonLad
    BuxtonLad , via OnePlus 7 Pro , May 31, 2020 :
    Jay2020
    Worst-case scenario you may have to Factory Reset your phone. If you still have the problem after that, the issue is likely hardware related.​
    sorry wrong post
  20. BuxtonLad
    I too am experiencing the issue whereby the call recording is not appearing within the hamburger menu. the calls are recording however. just means I have to manually navigate to the folder with the recordings. strange. I'm in the UK.
