100
[SURVEY INSIDE] OxygenOS Open Beta 14 for the OnePlus 7 Pro and 7
  1. Artemus
    Moderator, Community Hero 2020 Moderator May 31, 2020
    Artemus , May 31, 2020 :
    I'm pretty sure it is. Are you using the stock dialer to record or a third-party call recorder?
  2. BuxtonLad
    Gingerbread May 31, 2020
    BuxtonLad , via OnePlus 7 Pro , May 31, 2020 :
    yes. stock app. im running beta 14. I'm going to install the stable software and then reinstall beta.
  3. jeevan_naik
    jeevan_naik , via OnePlus 7 Pro , May 31, 2020 :
    no drop or any physical/liquid damage.. have also completely reset my phone no use.. I even rolled back to pie & back to OP14.. the issue is still there..
    I guess the only option is to go to the service center, once the current global situation is settled. Till then I have to get along with this.
  4. AbhishekDuragkar
    Cupcake May 31, 2020
  5. BuxtonLad
    ok. I installed 10.0.6 stable on my op7 pro. then went to upgrade to beta 14 but system update telling me the beta is older than 10.0.6 and will not install? do I now have to wait for beta 15 before I can go to beta again?
  6. Nonochiken47
    Nonochiken47 , via OnePlus 7 Pro , May 31, 2020 :
    Yes you have to wait beta 15
  7. BuxtonLad
  8. YBNPRASAD
  9. Cervantes
    Moderator Moderator May 31, 2020
    Cervantes , May 31, 2020 :
    Hi
    You are in beta rom You only receive beta OTA
  10. jeevan_naik
    Maybe.. I face this issue only in the settings app, sometimes noticable in instagram & rarely in playstore (depending on the app icon, especially if it has super dark background).
    I guess I only face this issue if there is a amoled black in the application. since amoled black turns of the pixel if it's black, maybe it's having problem turning on & off..
    Not sure guess have to get it checked.
  11. Swejuggalo
    OnePlus 9 Series Expert Community Expert May 31, 2020
    Swejuggalo , via OnePlus 7 Pro , May 31, 2020 :
    This is a limitation of amoled/oleds and has been complaints on that like forever. It's more visible the lower brightness you have and most visible with gray on pure black background. One of the reasons dark modes often avoid pure black. The effect can be similar to say that Gray To Gray (GTG) delay becomes to so long that you start to see it.
    We need to get a new screen technology to get away from this completely. You can basically check any oled type on any phone and you can replicate it with pure black and gray objects moving in low brightness. For example near identical delay on an Samsung S10+ (yeah... Wife forces me to see a Samsung in the appartment 😋)
    naikjeevan likes this.
  12. naikjeevan likes this.
  13. naikjeevan likes this.
  14. Last edited by a moderator: May 31, 2020
  15. Swejuggalo
    Search "oled black smear" on YouTube and you see what he means. Above 50% brightness it's more or less gone. The darker you go the more you get.. Even the self announced "GOD of phones" has these issues on their oled variants 😋
    Look at the border between black and gray
    Deactivated User likes this.
  16. vriesdejoop
    Ice Cream Sandwich May 31, 2020
    vriesdejoop , May 31, 2020 :
    and you wonder why, even if you give the answer yourselve..... :confused:o_O You really don't have a clue what you are doing or talking about....:(
  17. O1578234034326 , via OnePlus 7 Pro , May 31, 2020 :
    I have clue and today I got it stable update mentioned image
    I think clock style only available for beta only and not stable
