100
[SURVEY INSIDE] OxygenOS Open Beta 14 for the OnePlus 7 Pro and 7
  1. RainGater
    Gingerbread Jun 5, 2020
    RainGater , Jun 5, 2020 :
    Even though the force-dark mode is hidden, you can enable it via adb:
    Enable Dark Mode: adb shell settings put secure ui_night_mode 2
    Disable Dark Mode: adb shell settings put secure ui_night_mode 1
    Auto mode, based on the time of day: adb shell settings put secure ui_night_mode 0
    colossusr likes this.
  2. J1583770912480
    Cupcake Jun 6, 2020
  3. TheMysticalShaman
    Honeycomb Jun 6, 2020
  4. Ajsat3801
    Gingerbread Jun 6, 2020
    Ajsat3801 , Jun 6, 2020 :
    Hi, I'm on op7 oos 10.3.3 and I tried to install open beta from the op.. I'm getting this following message
    So does that mean I cannot install this build and I have to wait for the next release?
    1591432506614.jpg I downloaded it from here
  5. TheMysticalShaman
    SHIVAM97MANGLA likes this.
  6. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 6, 2020 :
    Since 7 series and up no (not without root and stuff anyway). Seen people managing to rollback on rooted devices with no wipes
    Artemus. likes this.
  7. TheMysticalShaman
  8. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 6, 2020 :
    Probably the least work that way. We never known what issues next major version upgrade brings [e]1f609[/e]
  9. colossusr
    Froyo Jun 6, 2020
    colossusr , Jun 6, 2020 :
    Disable automatic brightness from display settings
  10. TheMysticalShaman
  11. G_Kevin_Roy_Cjed
    Cupcake Jun 6, 2020
  12. Artemus.
    Nougat Jun 6, 2020
    Artemus. , Jun 6, 2020 :
    What version are you on right now?
  13. G_Kevin_Roy_Cjed
    Cupcake Jun 6, 2020
  14. Artemus.
    Nougat Jun 6, 2020
    If it's newer, no.
  15. G_Kevin_Roy_Cjed
    Cupcake Jun 6, 2020
  16. ASCHENTE_V
    Jelly Bean Jun 6, 2020
    ASCHENTE_V , Jun 6, 2020 :
    'Cause it's most likely not in the internal storage.
  17. G_Kevin_Roy_Cjed
    Cupcake Jun 6, 2020
    G_Kevin_Roy_Cjed , via OnePlus 7 , Jun 6, 2020 :
    i have moved the file to internal storage from download but still no luck i am trying india version of the OnePlus software should i select global version
  18. ASCHENTE_V
    Check over this.
    Artemus. and G_Kevin_Roy_Cjed like this.
