100
[SURVEY INSIDE] OxygenOS Open Beta 14 for the OnePlus 7 Pro and 7
  1. G.DeStellano
    Donut Jun 9, 2020
    G.DeStellano , Jun 9, 2020 :
    My battery life has gotten terrible since Beta 14.
  2. wawanredblack
    Gingerbread Jun 9, 2020
    the_reckoner likes this.
  3. DMaarten
    Honeycomb Jun 10, 2020
    DMaarten , Jun 10, 2020 :
    Maybe try the more recent beta 14 and see if that helps.
  4. O1591705067635
    Cupcake Jun 10, 2020
  5. akks
    KitKat Jun 10, 2020
    akks , Jun 10, 2020 :
    What's the compatibility issue with truecaller UI? Truecaller app is an infamous scam
  6. the_reckoner
    Ice Cream Sandwich Jun 10, 2020
    the_reckoner , via OnePlus 7 , Jun 10, 2020 :
    bro we are on beta 14!
  7. Reymundo911
    Reymundo911 , Jun 10, 2020 :
    I am experiencing two issues:
    1st: When trying to select Navigation gestures (left and right), it does not work and the settings revert to Navigation gestures (bottom) behavior. Happening since Beta 14
    2nd: Since Beta 13, I am having an issue with some dev stuff. The Android App Bundle on the Play Store is delivering a configuration of mdpi when it should be delivering xxhdpi for the oneplus 7 pro.
    Please see the full stackoverflow post I made:
    https://stackoverflow.com/questions...vering-wrong-resource-bundle-through-internal
  8. yogi00
    yogi00 , Jun 10, 2020 :
    Dear oneplus open beta 14 is having a lot of bugs. please provide a update very soon
  9. Artemus.
    Nougat Jun 10, 2020
    Artemus. , Jun 10, 2020 :
    You gonna tell us what the issues are? Also, no one from OP reads this so your cries fall on deaf ears.
    Jay2020 likes this.
  10. akks
    KitKat Jun 10, 2020
    Yes, it's called "beta" for a reason. Hope you have reported all the bugs you encountered, to the team, to let them work on it.
    Jay2020 likes this.
  11. Jay2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , Jun 10, 2020 :
    Reymundo911
    REPLY:
    First you're installing other Beta's applications on this open beta OS and then want to complain that the open beta is buggy?? Installing crap apps on a good operating system is going to get you crap performance out of it. Second, why would anyone attempt to configure their phone to a beta application from the Play Store?? Are you trying to make the Open Beta on the phone fail?? If an app is incompatible after installing it, get the app off the phone. This thread is now up to 1,500 postings; most are the same question asked 1,000 times because so many Rookies don't take the time to read the thread before posting, have no clue how to search a problem on line, install bad apps and make changes in Developer Options without a clue of what their doing and then wonder why their phone is giving them CRAP!
    https://support.google.com/googleplay/answer/7003180?hl=en
  12. O1591802725736
  13. Artemus.
    Nougat Jun 10, 2020
  14. Reymundo911
    I guess I can understand your frustration, but your assumptions are wrong. First, I am not complaining. This is my own application, developed by myself. I am keenly aware of how the android operating system works and what most of the developer options are used for. Isn't this thread used to signal to OnePlus developers that they introduced bugs in their software?
    Before Beta 13 the internal test apps and android app bundles were being deployed to my OP7P correctly. I want the devs to know so they can fix the problem.
    jvangat17 likes this.
  15. ASCHENTE_V
    Jelly Bean Jun 10, 2020
    ASCHENTE_V , Jun 10, 2020 :
    If you wanna "signal to OnePlus", there's feedback button... By writing here, they will most likely notice nothing.
    Artemus. and Reymundo911 like this.
  16. runforfun
    Gingerbread Jun 10, 2020
  17. bagpiper
    bagpiper , via OnePlus 7 Pro , Jun 10, 2020 :
    Hi All, is anyone else suffering from the touchscreen intermittently becoming non responsive on this Ob14? I have had this happen on YouTube and chrome browser.
    Thanks.
    akanbaz89 likes this.
  18. Swejuggalo
    Lollipop Jun 10, 2020
    Swejuggalo , via OnePlus 8 Pro , Jun 10, 2020 :
    Strange issues yes, but not really linked to YouTube or Chrome. You never got any warning System UI crashes or sonething like that when that happened?
  19. bagpiper
    Hi, no ui crash at all. I can still press the icon to end all the applications and then it starts working when I restart youtube or chrome.
  20. Swejuggalo
    I hardly use Youtube on the phone. And I barely never use Chrome. Quite a few have reported issues with Chrome though. Been trying to replicate some of my issues from beta 13/14 on 8 Pro. So far replicated one of them... You could send in a feedback report to Oneplus via the feedback tool
    akanbaz89 and bagpiper like this.
