Good update, thank you for it. A few things I'd like to suggest:
1.) If you pull down your finger on the notification on the Lock Screen, you can view the full message, you can also see 2 buttons: mark as read and answer. But it is visible only for the time you keep your finger there, as soon as you lift your finger the notification isn't extended and you can't read the full message, neither answer for that.
2.) The Night mode turns on every time when you unlock the phone, with some delay, doesn't matter what is your setup or preference (mine is that it is enabled from sunset to sunrise); the screen will burn out your eyes before the Night mode turns on, dims the screen and makes that yellow'ish.
3.) The Horizon light is currently useless. It shows up only once, when you receive a notification, and not anymore. It means, if you can't see it when you just receive the message, you won't spot that you have an active notification. It should blink a few times, at least.
4.) You receive a notification sound every time when you receive a message. Even if the phone is unlocked and is in your hand. Could you add an option to disable notifications when the phone is unlocked (so most probably you are actively using it)?
EDIT:
5.) Possibility to turn off the Lock Screen's PIN's ripple/waves. It's a security breach. Every time I enter my SIM's or Lock Screen's PIN those big grey circles mark what did I just hit. Not only the guy next to me can see it on the train but about everybody.
