92
[SURVEY INSIDE] OxygenOS Open Beta 15 for the OnePlus 7 Pro and 7
  1. Aniketh7
    Eclair Jun 13, 2020
    Aniketh7 , via OnePlus 7 , Jun 13, 2020 :
    It's been fixed? did they add the full pocket mode in utility or completely removed it?
  2. krishigandhi
    Donut Jun 13, 2020
    krishigandhi , via OnePlus 7 , Jun 13, 2020 :
    I suggest all of u guys who are deciding to download Open beta 15 as it has many glitches
    The one which I personally hated the most is that the mic is not working while playing
    I'm totally upset with OP rolling our beta updates with this many glitches
    Please dont install beta 15 You will not like it!!
  3. tarun17
    Gingerbread Jun 13, 2020
    tarun17 , via OnePlus 7 Pro , Jun 13, 2020 :
    @developers, it seems that I am not the one, request you to please look into it.
  4. tarun17
  5. Hasan39
    Cupcake Jun 13, 2020
  6. Artemus.
    Nougat Jun 13, 2020
    Artemus. , Jun 13, 2020 :
    No developers read this.
  7. tarun17
  8. akks
    KitKat Jun 13, 2020
    akks , Jun 13, 2020 :
    No.
    tarun17 and Artemus. like this.
  9. CKKHEMKA
    CKKHEMKA , Jun 13, 2020 :
    I have received 1 update today, thereafter battery of one plus 7 is draining. please help.
  10. Fahim_Arshad
  11. Artemus.
    Nougat Jun 13, 2020
    With every update, the battery MUST be calibrated.
  12. Hasan39 likes this.
  13. BrauliX
    BrauliX , Jun 13, 2020 :
    Anyone lost caller id with last update beta 15 on OP7PRO?
    all my ncall or missed calls are all unknown now
  14. tagilso
    Eclair Jun 13, 2020
    tagilso , via OnePlus 7 , Jun 13, 2020 :
    not fixed for me and still no option available in menu
  15. pgomes2000
  16. Jav P
    Honeycomb Jun 13, 2020
    Jav P , via OnePlus 7 , Jun 13, 2020 :
    No, you don't need root. In that case "root" means that you need to move the zip file to the root folder after downloading it.
    If you want my advice, if you don't know the answer for this kind of questions maybe you should reconsider switching to the beta path and better stay with the stable updates.
  17. pgomes2000
    pgomes2000 , via OnePlus 7 , Jun 13, 2020 :
    I know, but I only can move to the root of the SD card not the phone.
    I tried to move to the root of SD card but the settings /local location didn't recognize it.
  18. pavanvenkat
    Eclair Jun 13, 2020
  19. Jav P
    Sorry, what? This is what some people refer, in this case, as root. Depending on the method you used to download the zip file it could be in the Download folder.
    Again, I think you should take my advice seriously.
  20. Shirou93
