92
[SURVEY INSIDE] OxygenOS Open Beta 15 for the OnePlus 7 Pro and 7
  1. Artemus.
    Nougat Jun 27, 2020
    Artemus. , Jun 27, 2020 :
    Read the title. This is Beta 15, you're on 10.3.3 which is stable.
    DMaarten likes this.
  2. Narada2XK
    Cupcake Jun 28, 2020
    Narada2XK , via OnePlus 7 Pro , Jun 28, 2020 :
    Hey guys, I noticed that the brightness was not adjusting the brightness at all. I rebooted the next day and it was fixed.
    I noticed a notification that call recording was only supported in certain countries.
    The sound output is a lot quieter and on that note, another notification popped up at some point allowing me to know that there's a "raise phone" feature to soften the ringtone on by default.
  3. prasad321
    Gingerbread Jun 28, 2020
    prasad321 , via OnePlus 7 , Jun 28, 2020 :
    Jay2020
    Rolling back, how's it working for you?​
    I also wanted to be on Open Beta 15 but before moving to open beta i wanted to check how i can move to stable so i have downloaded rollback build and flashed it. Some how i was not able to get OTA due to some WiFi issue so downloaded 10.0.3 locally and installed it. similarly 10.3.3 can be flashed. Hope this will help.
    Note: upgrading OB 14 to OB 15 will not delete data but downgrading / moving to stable will delete the entire data. Take backup before performing any operation.
    GPsOP and Jay2020 like this.
  4. B1572816038978
    B1572816038978 , via OnePlus 7 Pro , Jun 28, 2020 :
    Hi all! Just want to update this after a week of use: it works fine for me pretty fluid experience no issues with brightness or lags. Sorry to hear so many people here with problems reading all your comments makes me feel lucky as I never had issues with any Beta updates so far. Keep up the good work OnePlus Team! Please deliver us Android 11 this year!
  5. Petzkub
    Froyo Jun 28, 2020
    Petzkub , Jun 28, 2020 :
    Hey @prasad321 where did you find the rollback package? Please share the link. There used to be a direct link in op to the rollback package, but now there isn't. I've already backed everything up, but I just cant find the rollback package. Tried to install the latest official build also, but it won't install from local upgrade.🤔🤷🏻‍♂️
  6. Jaydalvi21 , via OnePlus 7 Mirror Red , Jun 28, 2020 :
    Portrait mode not working properly in medium light conditions.thats very disappointing.its blurs the face and focuses on backgroud after taking pictures. Is anyone else facing this problem. And one more video recording in 1080p60 it takes redddish saturated video n that's ambarrassing a lot.
  7. DMaarten
    Honeycomb Jun 28, 2020
    DMaarten , Jun 28, 2020 :
    Is anyone else facing this problem.. Only multiple topics every day because people are too lazy to use the search and see it has heen reported, talked about, and discussed dozens of times already. o_O
    rpkkiran, vriesdejoop and Artemus. like this.
  8. Artemus.
    Nougat Jun 28, 2020
    Artemus. , Jun 28, 2020 :
    I face this daily. :rolleyes:
  9. prasad321
    Hi please check below link for open beta 1 for OnePlus 7 and 7 pro. Here tou can find the rollback for android 9.
    https://forums.oneplus.com/threads/...-for-the-oneplus-7-and-oneplus-7-pro.1099154/
    Petzkub likes this.
  10. Chand6391
    Froyo Jun 28, 2020
  11. GPsOP
  12. vriesdejoop
    Ice Cream Sandwich Jun 28, 2020
    vriesdejoop , via OnePlus 7 Pro , Jun 28, 2020 :
    No, no ota. You can always go back to stable with a newer rom as the beta you have on your phone. BUT.......... IT WILL WIPE YOUR PHONE BACK TO FACTORY SETTINGS.
    So before going back to stable make s very good backup of the things you want to keep.
    Artemus. and GPsOP like this.
  13. GPsOP
    GPsOP , via OnePlus 7 , Jun 28, 2020 :
    Thanks vro ; )
  14. R1574325926675
    Cupcake Jun 29, 2020
    R1574325926675 , via OnePlus 7 , Jun 29, 2020 :
    Hello OP7 developer team, After current update bita14 im facing below problem in my op7. 1, after charging plug remove Steel in the top side corner my phone is showing that phone is under charging. 2, phone is very luggi taking much time to do any task in phone 3, ambient display is not working 4, battery is draining like snowfall 5, qnd in last one year you have not fix main camera problem still click picture colour are very difference in main camera shut
    Ram.24 likes this.
  15. K1577118792258
    JohnTex and Jithu_Raj07 like this.
  16. 22sunny22
    Froyo Jun 29, 2020
    Jay2020 likes this.
  17. Artemus.
    Nougat Jun 29, 2020
    Artemus. , Jun 29, 2020 :
    Beta problems belong in the beta thread.
  18. DMaarten
    Honeycomb Jun 29, 2020
    DMaarten , Jun 29, 2020 :
    Macro not gonna happen
    Artemus. likes this.
  19. SVM911
    Gingerbread Jun 29, 2020
    SVM911 , via OnePlus 7 Pro , Jun 29, 2020 :
    Macro mode was there on early beta and 1 stable build and it was working pretty well but idk why they removed it from OnePlus 7 pro.
    I think that they knowingly removed this because of 7t series launch with macro mode gimmick.
  20. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 29, 2020 :
    Testing a software feature... and then releasing something with both software and hardware changes.
    I never saw it in any stable version....
    "Pretty well" might not be what they were looking for.... They tested the software changes for a feature function. The test got the results they wanted. Test over.
    Beta get features that needs testing. Some stick. Some is there temporary (super macro). Some might return in a reworked form (1 handed mode).
    They are not forced to release a test feature in final form. In this case the final form needed hardware modification too.
